Monitor 40 or RTi6?
Looking at these two, either new leftovers or refurbished from the Polk store on Ebay. Similar specs. I have a sub so the bass response of either should be fine. Use will be mostly TV/movies with maybe 10% music (although that could increase if I really like them
Your thoughts? (Don't have room for towers so don't even suggest them
Post edited by lmacmil on
The rti6's are good bookshelf for HT.
The RTI's are typically a better HT speaker. I have the A3's which are the newer model of the 6's. I like them quite a bit, but all the book shelfs really need a sub for HT. I would look at getting a center channel as well. Depending on your budget take a look at the RTiA3's on polk direct as well.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
packetjones wrote: »The RTI's are typically a better HT speaker. I would look at getting a center channel as well. Depending on your budget take a look at the RTiA3's on polk direct as well.
Yes, the plan is to get the center channel from the same series. Don't see the RTiA series on Polk Direct much. Too new I guess. -
Go for the RTi6sLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
For movies go with the Rtis...a good bookshelf for that.
