Monitor 40 or RTi6?
lmacmil
lmacmil Posts: 122
edited January 2010 in Speakers
Looking at these two, either new leftovers or refurbished from the Polk store on Ebay. Similar specs. I have a sub so the bass response of either should be fine. Use will be mostly TV/movies with maybe 10% music (although that could increase if I really like them :D )
Your thoughts? (Don't have room for towers so don't even suggest them :( )
Post edited by lmacmil on
  • anton.chigurh
    anton.chigurh Posts: 239
    edited December 2009
    The rti6's are good bookshelf for HT.
  • packetjones
    packetjones Posts: 1,059
    The RTI's are typically a better HT speaker. I have the A3's which are the newer model of the 6's. I like them quite a bit, but all the book shelfs really need a sub for HT. I would look at getting a center channel as well. Depending on your budget take a look at the RTiA3's on polk direct as well.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • lmacmil
    lmacmil Posts: 122
    edited January 2010
    The RTI's are typically a better HT speaker. I would look at getting a center channel as well. Depending on your budget take a look at the RTiA3's on polk direct as well.
    Yes, the plan is to get the center channel from the same series. Don't see the RTiA series on Polk Direct much. Too new I guess.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    Go for the RTi6s
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    edited January 2010
    For movies go with the Rtis...a good bookshelf for that.
    cnh
