PS3 media center
greg2350
What software would you suggest I use to use my PS3 as a media center to connect to my PC. both PC and PS3 are hardwired. Thanks in advance.:)
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
AVR: Denon 3801
Sat: Directtv HD 10
Post edited by greg2350 on
+1 Excellent software that's free.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
i use ps3 media server also and its good enough.. you can look at tversity also.
I've just dug in to TVersity and it seems very easy to use so far. I can play all my AAC files as well, not sure if ps3 media server does that or not.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
+1 on Google server, I use that too but in a wireless conifguration which is very convenient if your computer is on the second floor and your gear on the 1st?
cnh
even more convenient when your PC is on the 2nd floor and your HT/gaming is in the finished basement. Mine is hardwired though. -
Google by far. Easy to use, easy to setup.
avelanchefan wrote: »Google by far. Easy to use, easy to setup.
+ 100000000000
for some reson I can't get my music to play through the media server right now. not sure why. I can stream movies/videos. it sees the files and plays them but no sound.
