Quick 1.2TL bi-wire question
chandler9a
chandler9a Posts: 878
edited January 2010 in Vintage Speakers
Hey guys, I was just double checking to see if I needed the A-1 cable if I want to use two NAD 218 amps to power the SDA 1.2TL's... one for the highs and one for the lows using RCA splitters.
I didn't think I did but I just wanted to make sure in case I was wrong.
Any advice on this is greatly welcomed.
-Chandler
Post edited by chandler9a on
    F1nut Posts: 52,005
    edited December 2009
    You'll be fine as long as the amp used for the lows is common ground.
  • chandler9a
  • george daniel
    george daniel Posts: 12,096
    Not to be insulting,,be sure to remove the jumpers,,have fun,,let us know how it sounds,,as in differences vs single amplification.:)
  • chandler9a
    Luckily we did remember to remove those, thanks though.:)
    So far the clarity is very apparent and it sounds really good! We are still working on placement with the speakers and subwoofer to get better bass response... side walls, back walls, and distance between all being taken into consideration of course.
    Who knows, could just be the recordings we have listened to so far.
  • chandler9a
    edited January 2010
    Just got everything set for the bi-wire project including bass adjustment on the 1.2TL's and it is VERY impressive... these NAD 218 THX amps really put out some great power.
    Some day we I would love to try an extremely high current/ quality power amp to see the difference but for now there are no complaints and look forward to future mods!
    thanks all for the input...
  • george daniel
    edited January 2010
    Good to hear that it's sounding well,,keep on having fun.Thats an order,,ya heah':)
  • awe-d-o-file
    awe-d-o-file Posts: 146
    edited January 2010
    I remember first bi-wiring and finally bi-amping my 1.2's and what an improvement it made. Enjoy! I was an NAD dealer back in the day and sold a few of those amps - none ever had problems.
    ET
    ET
    System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
    Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
    Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
