Sending AVR pre-out signals wirelessly
math wizard
math wizard Posts: 106
Is there any product on the market that can send the signal from the pre-outs of an AVR to an amplifier via wireless? I would like to place the amp for my surrounds closer to the speakers (shorter runs of spearker wire). From a previous post, it was advised against using long runs of IC's.
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
Post edited by math wizard on
  • Serendipity
    Serendipity Posts: 6,975
    edited December 2009
    I believe some HTIB's have this feature but as a separate add-on I haven't seen any on the market.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • thuffman03
    thuffman03 Posts: 1,325
    IMO it would be best to keep your amp and your pre close to gether and run longer speaker cables.
    How far away are your speakers from the preamp?
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Ricardo
    Ricardo Posts: 10,634
    The technology exists (wirless subwoofers and powered speakers), but I don't think it's available for use with a common AVR-Amp.
    Someday this will for sure be available. We will then talk about the "air treatments" that makes for a better wireless transmission ;)
    I am enjoying the bluetooth ipod streaming into my car stereo. Sounds pretty good to me, and if the air is really cold the bass sounds a lot better :)
    SOPA
  • kcoc321
    kcoc321 Posts: 1,788
    I have seen a unit designed for a wireless connection to a subwoofer. One unit plugs into the receiver one into the sub. I am sorry IDK the name but I think I bookmarked it. I search them and let you know if I find it. It does exist :)
    I can't say if it would work for F/R though.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    kcoc321 wrote: »
    Polk makes a wireless sub, it is the PSWi225, not sure if that was what you were talking about.
    -Jeff
    http://www.polkaudio.com/homeaudio/psw/pswi225.php link
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • kcoc321
    I can't find the one I bookmarked, but here are a couple I found through a search.
    They are not exactly what you wanted as they have built-in amplifiers. The Rockfish are 25wpc each and the KEF are 50wpc. Can't say how well they work, but they are a solution to you problem.
    Rocketfish reviews not so good. :(
    http://reviews.cnet.com/speakers-speaker-systems/rocketfish-universal-wireless-rear/4505-6467_7-32456886.html
    KEF: $450 ouch
    http://www.accessories4less.com/make-a-store/item/KEFWIRELESS/KEF/universal-wireless-speaker-connector-system/1.html
    I can tell you that I used AQ-ICS cabling for a DVD player that was 25-30ft from my receiver (it was on the back shelf with my projector) and it worked okay for me. Maybe you could locate the amp halfway between the front and the back?
    Added: Jeff, Yeh I have seen that, but he would need both a sender and a receiver for it to work. The Wireless Polk sub has the receiver built in. (As near as I can tell)
  • Zitro
    Zitro Posts: 864
    Any wireless audio product I've heard performs poorly compared to a wired system; I'll deal with cables.
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • wutadumsn23
    kcoc321 wrote: »
    Very true, I wasn't sure either.
    Zitro wrote: »
    +1, never cared much for the whole wireless surround craze myself.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
