Polk XRt12 Antenna Problems
Jim in Houston
Jim in Houston Posts: 3
edited December 2009 in The Clubhouse
Has anyone experienced problems with the antenna connection on the Polk XRt12 XM receiver? I have tried two different antennas and had XM resend the single, but still I get a "No Signal" message.
Post edited by Jim in Houston on
  • Serendipity
    Serendipity Posts: 6,975
    Is the unit activated?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Gadabout
    Gadabout Posts: 1,072
    Jim,
    Welcome to club polk....
    You using the one that came with it or are you using an aftermarket one?
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • exalted512
    exalted512 Posts: 10,735
    shouldnt matter. Even if its not activated it should get a signal and the preview channels.
    -Cody
  • hearingimpared
    hearingimpared Posts: 21,136
    Call Polk Customer service, they will help you out.
  • Serendipity
    exalted512 wrote: »
    -Cody
    When my XM tuner was not activated I had to call CS to refresh the unit.
  • Jim in Houston
    I am using an after market commercial type antenna through coax. I switched to a small antenna that came with my XM Roady and it worked for a while, but now just says "Antenna" using either of them. I think it must be an internal connection problem in the unit.
  • exalted512
    you could certainly be right. I install the car ones all the time and you never have any problems with it not being activated.. The home tuners could be different.
    -Cody
  • Gadabout
    Jim,
    Sorry for the slow response. The reason I asked about the antenna is that I have had a few issues using regular coax with correct adapter. However, the antenna that came with it has never given me any issues.
    I suspect your correct that it might be an internal problem since both types of antenna's are not getting through to the reciever. Give Polk customer service a call. Great folks there and I'm sure they can help resolve the issue.
    Scott
  • Serendipity
    Gadabout wrote: »
    Jim,
    Scott
    +1
    I'm sure they will resolve the issue for you.
  • Jim in Houston
    Thanks to all who tried to help. After talking with the Polk technician, I decided to purchase a refurbished unit which should ship today.
    Happy New Year to all!
