In the market for a new receiver 500 or less
Jdogg711
Jdogg711 Posts: 7
edited January 2010 in Electronics
I recently acquired a pair of rti8's to go along with a cs 10 center and r300 surrounds. My old receiver quit on mr and I was hoping to find a new one with a budget of $500 although less would be better. I would like to be able to biamp the rti8 to provide them with enough power. I'm new to the receiver market and was hoping I could get some suggestions. Any help would be appreciated. Thanks.
Post edited by Jdogg711 on
  • Sherardp
    Sherardp Posts: 8,038
    edited December 2009
    Onkyo 805 or 885. If you can stretch it 699 you can get a kicka$$ Pioneer Elite SC25.
  • coolsax
    coolsax Posts: 1,826
    you can also look at the Yamaha V665, its right around $500 and its has preouts should you want to add external amplification in the future.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • superjunior
    superjunior Posts: 1,632
    you should also be able to get an older pio elite 92 or 94 in that budget
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • anton.chigurh
    anton.chigurh Posts: 239
    I'd think about a refurb hk 354 off the ebay store...<$400. They're a great value. Put the extra $100+ towards a sub if you don't have one yet.
  • Jdogg711
    Jdogg711 Posts: 7
    sorry but I cant seem to find any except the yamaha for anywhere close to under 500 dollars. Any other suggestions?
    Also, any other thoughts on the yamaha v665?
  • superjunior
    Jdogg711 wrote: »
    not familliar with the yammy but have you considered used?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • genjivn
    genjivn Posts: 101
    Frys website has a nice deal on the harman 3550HD for ~$649 plus tax. It is quite a nice receiver for a little bit more than your budget
  • jimmydep
    jimmydep Posts: 1,305
    I've got the Yammy v-665 that I use as a pre-pro with no complaints. The amplifier section falls short, although It was powering an LSI surround system. If you don't drive it too hard it should be fine until you're ready for a separate amp.
  • Des Moines
    Des Moines Posts: 115
    check out the new Marantz SR5004. I auditioned last week and was impressed with the clean sound. Ive had HK receivers for many years and now running HK AVR 520 but thinking about upgrading to a receiver with HDMI. For me the short list will be HK and Marantz fwiw. The deal below will keep you under your $500 budget.
    http://www.accessories4less.com/make...eceiver/1.html
    cnh commented that 80-90 wpc will not be enough to drive SDA 1Cs in a 5.1 surround. My HK has enough power to drive my 2.1 / 3.1 setup but is defininatley not up to the task for 5.1 as cnh stated.
    HT in Progress
    Receiver - Harmon Kardon AVR520 5.1
    Fronts - Polk SDA 1C
    Center - Polk CS350
    Monitor - Sharp Aquos LCD
    NMT - Mede8er500x
    Cables - Signal Ultra
  • Serendipity
    Serendipity Posts: 6,975
    Onkyo 60x series.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Polkitup2
    Polkitup2 Posts: 1,641
    You can get an Onkyo TX-SR707 from Amazon for $499 shipped.
  • asmd
    asmd Posts: 48
    Sherardp wrote: »
    where would i find the sc-25 for 699?
  • Kingface
    Kingface Posts: 58
    For $500 I would go out and buy a nice used receiver. Do not be afraid to do this. I have 2 receivers that when new sold for over $1200.....I got them both for under $500. Sure they are 3-4 years old and might not have a lot of current connections but there are ways around those shortcomings. What you will gain is a much better amp section, better DAC's and just a better build quality.
    You can get a used Denon 3806 for about $450 or a 3805 for under $300 right now.....they will mop the floor with any mentioned so far....
    Onkyo TX-NR809
    Boston Acoustic VS 260 - Mains
    Boston Acoustic Vr920 - Center
    Boston Acoustic Micro 90 - Surrounds
    Boston Acoustic HPS 12HO - Sub
    Samsung LN40b650 - LCD Monitor
    Yamaha Rx-v2200
    Polk Rti 70 - Mains
    Polk Cs245i - Center
    Polk Rt/Fx - Surround
    Boston Acoustics Vr500 - Sub
    Optoma HD20 Projector
  • anhchungdoan
    anhchungdoan Posts: 760
    asmd wrote: »
    NIB? I would buy one and send you Oliver Garden GC dinner for 2. Just tell me where. Deal ?
  • Kingface
    Kingface Posts: 58
    I'll throw in the drinks....... lowest I have aver seen was $950.....and not from a reputable place....
    Onkyo TX-NR809
    Yamaha Rx-v2200
    Polk Rti 70 - Mains
  • asmd
    asmd Posts: 48
    edited January 2010
    no luck with 699 for the sc25.
    settled for a vsx23 for 560 instead.
    dont need a fancier amp, already emotiva to drive the big lsis..
    That MCCACC room correction is a tweakers wet dream!! awesome!
  • BAD ASP
    BAD ASP Posts: 361
    edited January 2010
    There's a Denon 5700 available on Audiogon. I have had one of these for about 5 years now and it is a fantastic reciever and I can highly recommend it. They are asking $550.00. It's a 5.1 with preouts and a great amp section at 140wpc. No hdmi if that matters.
    No affiliation..
    good luck
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • C'VILLE
    C'VILLE Posts: 28
    edited January 2010
    If you are interested, I have a Black Denon AVR3806 Receiver that has never been used. I was going to buy a house and it never worked out. I have finally decided to sell the receiver and along with my Polk RTI10 Cherry Standing Speakers. I have already sold my FXI3's and CSI5. I am in Charlotte, NC 28269. I can be reached at dlaw11@carolina.rr.com.
  • cstmar01
    cstmar01 Posts: 4,424
    edited January 2010
    C'VILLE wrote: »
    dude seriously, if your selling stuff it needs to go into the FS section, I think over half of your meaningless post have been you trying to either sell your Denon or RTI and its getting annoying.
  • finfan66
    finfan66 Posts: 27
    edited January 2010
    I have the Yamaha Receiver and I like it. I had an Onkyo before and I love my Yamaha tons more. The only receiver that I would buy used is Carver!
    Main Speakers - Polk Audio RT 2000I
    Center Speaker - Polk Audio CSI 400I
    Rear speakers - Polk Audio FX 500I
    10" Sub - Polk Audio PSW 450
    Receiver - Onkyo TX-NR807
    Onkyo C-S5VL CD player
    Yamaha TX-497 tuner
    Sony PS-LX110 turntable
    Sony Bravia KDL-52XBR9
    PS3 120GB
  • Kingface
    Kingface Posts: 58
    edited January 2010
    finfan66 wrote: »
    Why?
    Onkyo TX-NR809
    Yamaha Rx-v2200
    Polk Rti 70 - Mains
  • anhchungdoan
    edited January 2010
    Kingface wrote: »
    Why?
    Oh, that's old sentimental reason: Love is blind. :D
    edited January 2010
    Kingface wrote: »
    The older 3800s are very good but they won't mop the floor with the Onkyo 805 mentioned above...that's a 51lb AVR with Burr Browns and a real 130 Watts/channel at 5.1 ratings? But you are right about the lower models mentioned.
    cnh
  • Kingface
    Kingface Posts: 58
    edited January 2010
    cnh wrote: »
    cnh
    I agree....forgot that unit was mentioned. The 805 is a beast. My buddy had one. It sounded very nice but he had a lot of synch issues with the HDMI connections and you could fry an egg on the thing it got so hot. Excellent receiver though for the price.......I'd still take the Denon 3806 because I prefer the sound quality a bit more and trust their reliability over Onkyo.....but it's REALLY close.
    The thing that I really appreciated about that 805 was how much better it was than the 804. Rarely do you see a electronic manufacture upgrade the same 'model' that much. I think the 805 single handedly brought Onkyo back into the receiver battle with Denon, Yamaha, HK etc. Onkyo's used to sound very shrill and their build quality was very poor in the early 2000's. I think the 805 put them back on the map so to speak......
    Onkyo TX-NR809
    Yamaha Rx-v2200
    Polk Rti 70 - Mains
