Need help with my subwoofer's bass
JDScarface
Hello.//i had bought a psw110 subwoofer a while back that i had connected to a all-in-one panasonic receiver.., and after some advice from people/..i decided to buy a different receiver..i just bought it yesterday and i hooked everything, but i cant seem to get the subwoofer to be putting out bass as i thought it would..and im using a single rca cable hooked up to the sub out connection..and this is the receiver i bought..what can i do to make the subwoofers bass rattle or be noticeable???
http://www.bestbuy.com/site/Sony+-+500W+5.1-Ch.+A/V+Home+Theater+Receiver/9245523.p?id=1218066769427&skuId=9245523&st=sony%20receiver&cp=1&lp=2
Have you checked the settings on the receiver to make sure that the level is acceptable? You may have to boost the signal going to the sub.
Again, if you're looking to rattle windows, you bought the wrong sub.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Have you checked the settings on the receiver to make sure that the level is acceptable? You may have to boost the signal going to the sub.
yea..i put it on +6 and you cant really much tell a difference,,,and which sub do you think is good enough to do that??
well see the thing is..before i bought the new receiver..there was much more bass then there is now..so do u think maybe the new receiver is the problem??it used to be connected to the panasonic home theatre
http://www.bestbuy.com/site/Panasonic+-+1000W+5.1-Ch.+Home+Theater+System+with+DVD+Player/9285436.p?id=1218074554732&skuId=9285436&st=ThanksgivingWeekendSale_HomeTheater&cp=2&lp=5 -
Is there a level control on the sub?
Judging a sub by how well it rattles your window isn't really something i can help you with... i don't really look for that. I would say just get something with a 15" driver and a huge amp if you're just looking for SPL only.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Is there a level control on the sub?
do u mean level control by..when it goes up +6 and -6..
well im not really trying to rattle windows or anything..i just want to have nice bass..and right now,..i cant really hear bass...when i sit next to the sub i kinda hear it..but when i go far away from the sub or where i sit..i cant hear any bass... -
JDScarface wrote: »do u mean level control by..when it goes up +6 and -6..
Is there a level control on the sub itself.....?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Is there a level control on the sub itself.....?
theres only a volume control knob and a low-pass filter knob.. -
JDScarface wrote: »theres only a volume control knob and a low-pass filter knob..
And you have each set to what?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Are you connecting using the LFE or are you running your Front left/Front right from your reciever to your sub and then from your sub to your speakers?
There is a good chance that if you are running direct from LFE, you might not be hearing your bass as pronounced when listening to music, but you're hearing it better when watching movies.
If you run your wires from your receiver to your sub and then from your sub to your speakers, you'll have your sub engaged anytime you are using your speakers (whether it's 2 channel or 5 channel).
? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
? Polk RTA 11TL's (FR and FL)
? Polk TSi200's (RR and RL)
? Polk CS10 (Center)
? Polk PSW-350
? Grado SR-60i Headphones
? Fii0 E5 headphone amp
? iPod touch (8 gig)
? iPod Classic (80 gig)
? Mac Mini (as media server)
? xbox 360 -
concealer404 wrote: »And you have each set to what?
the volume is at max and the low pass is around 120.. -
JDScarface wrote: »the volume is at max and the low pass is around 120..
Yikes, that sounds high. What are your main speakers again? I think you need to try what everpress said.
What is your crossover set at on the AVR?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
the way i have it connected as of right now...the subwoofer..cable which is a dynex $25 sub cable from the sub out pre out on the receiver to the right/red lfe in....the i have just for now..the center speaker and front left and right connected...
so r u saying that i should connect all the speakers to the back of my sub?? -
JDScarface wrote: »the way i have it connected as of right now...the subwoofer..cable which is a dynex $25 sub cable from the sub out pre out on the receiver to the right/red lfe in....the i have just for now..the center speaker and front left and right connected...
Is there a left AND right RCA jack on the back of the sub? Try the left. Don't know why, but if there's both, i always put it in the left one.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
You don't connect all your speakers to your sub. On the back you'll see left channel in/ right channel in and right under that, the outs for those.
You run your speaker cables for the front left and front right from your receiver to your sub and then from your sub to your front left and front right.
Make sure to unplug your LFE if you hook it up this way. Then readjust your settings on the sub. Set it back to what the factory sugests it to be and turn it down; you don't need to blow it trying to adjust it.
Then run some music through it and adjust for your taste.
Letus know if that helps; I know on my system I have abandoned the LFE completely and run my speakers in this configuration, mostly because my fronts are so bad **** that the sub is really only there for back up and a little tactile support (so I can feel the couch rumble).
? Polk PSW-350
? xbox 360 -
As I said in the other thread. If you are hearing bass close to it and than when you walk away you hear nothing. You need to relocated the sub. It is something a lot of us had to do when we first got our subs. You can not just sit it anywhere and have great bass.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
yea i tried what everpress said but..it still sounded the same..so then i decided to go ask the people at best buy..and one of the persons who helped me recommended that i should buy a splitter..and connect it to the subwoofer cable and then to plug it in the right and left channel...
when i tried that,,,it worked a lot better..and i also had it messed up on the receiver...i though i had switched the bass on the subwoofer...but i had put it up on the left/right and center speakers..which was making it sound nasty..
so like i said now that i plugged the splitter cable in..it sounds a lot better...so thanks to everyone who tried to help me!! -
bigaudiofanatic wrote: »As I said in the other thread. If you are hearing bass close to it and than when you walk away you hear nothing. You need to relocated the sub. It is something a lot of us had to do when we first got our subs. You can not just sit it anywhere and have great bass.
like i posted on the new reply..my subwoofer sounds a whole lot better from where i sit now.i can actually hear the bass now from where i sit...since im using the splitter to connect both white and red cables...
but im going to leave it how it is now for a couple of days..then im going to try to relocate the sub like u said to see if i can hear better bass...so thanks for ur help!! -
The splitter should have nothing to do with it... but glad it sounds better...
concealer404 wrote: »The splitter should have nothing to do with it... but glad it sounds better...
It's BestBuy.... they would sell a damn cable/splitter to you for a toaster oven... And a 3 year warantee that wasn't worth a damn.
? Polk PSW-350
? xbox 360 -
I have a splitter on mine either way it does not sound any different with or without it.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
This to me sounds like the receiver is not configured to use the LFE as an output. I had this issue with my new receiver. Once I engaged the LTE port by switching to a setting (other than Stereo or configuring Stereo to include LTE) the sub worked fine.
If this is not the case, it sounds like the wiring is incorrect.Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- RM 8 Center (center)
-- VM 10 (S.L/R)
-- DSW microPRO 1000 (LFE)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 6600 (L/R + center + S.L/R)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909 -
I have much the same problem, upgraded receivers and lost most of my bass. in an attempt to fix it , i purchased a 505, still have not huge amounts of bass. receiver is set to lfe, using sub out ect. any ideas?
was just reading other posts, you will need to know a few things. yamaha rxv 675, lfe out @ rec. rec @ 60hz (80/90 makes very little difference) small/large makes very little difference for speaker size. had an older htr yammy which had tons of bass with a velodyne 10". seems to be ok watching movies but have very little for music. have tried placement although it worked great with the other reciever, it doesn't help. have even tried both subs it but only makes it dirty not more pronounced. this forum is the best thing ive found for sound issues. awesome job guys!!!
Hi, I have also found that I need to manually tweak the bass output up having run the room correction setup, as the bass always sounds weak mif I stick to the settings applied by YPAO. Your Yamaha RXV675 is a very good receiver and should sound good on movies and music, so just edit the bass level in the menu and see how you feel then.
You do realize that this thread is 3 years old, right?Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
Teac R-919X ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
I have a Pioneer home theater receiver that will not power on the subwoofer at a reasonable listening volume unless it's at least at +5.5 dB (out of a maximum of +10 dB). Then again it also has a very odd volume scale of -94 dB to -18 dB.
When I do have analog attenutation on (in case ever I do want to play music much louder!), I still rarely turn music up past -50 dB receiver volume. Because of that, I had to use a subwoofer volume of +6.5 dB to consistently auto power on for music that would otherwise not have enough bass to power the sub on using a subwoofer volume of +5.5 dB.
(Even if this is an older thread, the information would still be useful.)
