Do these speakers match? (Urgent!)
stic
Hi folks, I already have the following 1 -- a pair of RTi4 speakers and a Yamaha receiver. I am about to buy the 2/3/4 to make a set of 6 speakers for my home theatre tonight! for the crazy Canadian boxing day sale. Can any one give me advice on whether they are good match? Any suggestion? Thanks a lot!
1.(A pair) Polk Audio RTi4 High Performance Bookshelf/On-Wall Speakers (Pair, Black)
http://www.amazon.com/Polk-Audio-Performance-Bookshelf-Speakers/dp/B0000E2XEB/ref=sr_1_24?ie=UTF8&s=electronics&qid=1261617333&sr=8-24
2.(A pair) Polk R300 2-way single black R Series floor-standing loudspeaker
http://www.amazon.com/Polk-2-way-single-floor-standing-loudspeaker/dp/B000NW11WQ/ref=sr_1_1?ie=UTF8&s=electronics&qid=1261617526&sr=1-1
3. Polk Audio PSW111 Compact Powered 8-Inch Subwoofer (Single, Black)
http://www.amazon.com/Polk-Audio-Compact-Powered-Subwoofer/dp/B000P0528U/ref=sr_1_1?ie=UTF8&s=electronics&qid=1261617562&sr=1-1
4. Polk Audio CS10 Center Channel Speaker (Single, Black)
http://www.amazon.com/Polk-Audio-Center-Channel-Speaker/dp/B0018QROM2/ref=sr_1_1?ie=UTF8&s=electronics&qid=1261671885&sr=1-1
Post edited by stic on
I have no idea on the matching, but damn, I wish I would have seen a deal like this on the Rti4's before I bought my M30's...grrr....- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
Here is the center channel you need.
http://www.amazon.com/Polk-Audio-Center-Channel-Speaker/dp/B0000E6S12/ref=pd_bxgy_e_text_b -
Hi jtgranby and xcapri79, thanks for your suggestions. But could you tell me why you recommend the others? Are they just better or do they match the RTi4 better?
They match you r RTi 4's better. This will help you out.
http://www.polkaudio.com/downloads/hthandbook.pdf
Good luck Check out Polk Direct for the Rti8's.
Jim -
Thank you, Jim. It helps.
