Pioneer SC-07 in stereo - no bass from SW
str8boostn
str8boostn Posts: 51
edited January 2010 in 2 Channel Audio
Help... I love this receiver, but I'm not sure how much it loves me.
I've looked over the manual... I'm sure what I'm looking for is in there... Just not in plain enough English for me.
I've never really used my home theater setup for listening to cd's... but now I want to.
I think I've switched it to every mode possible and I just can't get my subwoofer to play... and the couple of times that I have gotten it to play, it plays very weak... Even at full volume.
But it puts out super bass when watching movies, etc...
My setup is in my signature... Please help. Any advice is greatly appreciated.
Pioneer SC-07
Polk CSi5
Polk RTi10's
Polk FXi3's
Polk RTi6's
Polk PSW505
PS3 80G
Post edited by str8boostn on
  • coolsax
    coolsax Posts: 1,826
    edited December 2009
    it might depend on how you set it up... my yamaha when played in pure direct does not send a signal to my sub and plays in two channel only.. but i'm not sure how that works on the pioneer.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • Jetmaker737
    Jetmaker737 Posts: 1,116
    Do you have a separate CD player hooked up? If so, is it outputting analog or digital?
    Are your speakers set to "small" in setup? If not, you will probably not get subwoofer output with 2 Ch signal.
    Toolfan66 Posts: 18,053
    coolsax wrote: »
    The Pioneer works the same.
    xcapri79 wrote: »
    With the Pioneer SC07, in the Speaker setting, if you have any of the speakers set to "Large", set the Subwoofer SW to "Plus". The Pioneer SC07 is a marvelous AVR, I have yet to tap all of it's potential.
    Agreed!! I have yet to do the same but then again I play with my SDA's and Adcom gear more.
    xcapri79 wrote: »
    I see that Kmart has Adcom for great price. In the New Year, I'm going to get an Adcom amp for an Emotiva vs Adcom showdown with the LSi's.
    I say get the GFA 5802 used, for me it killed the XPA-2 you may have different findings. I still run the XPA-3 in my HT.
  • str8boostn
    edited January 2010
    xcapri79 wrote: »
    Thanks for all of the help... The simple fix was to just set the SW to plus... my fronts and center are set to Large. That got it to start working.
    xcapri79 wrote: »
    Well right now I have the Beatles playing in stereo with a XPA3 amp, (Pioneer PD-F1009 CD and Pioneer VSX-1018AH set to PCM direct) and two LSi15's and two PSW505's stacked. Simply Awesome.
    When you say "stacked" I'm assuming that you mean you are coming right off of the subwoofer output with a splitter and just running to separate SW wires?
    Sorry, I'm a little new to the whole Home Theater setup. But I want to run another sub as well...
    Pioneer SC-07
    Polk CSi5
    Polk RTi10's
    Polk FXi3's
    Polk RTi6's
    Polk PSW505
    PS3 80G
