Would you like a tube-powered iPod table radio for $100.00?
Danny Tse
Danny Tse Posts: 5,206
edited December 2009 in Electronics
Again, it's available at this price as of this post....
Acoustic Research (AR) AV100B tube-powered iPod table radio @ Amazon.com
I checked the owner's manual and it's powered by vacuum tubes. Which kind? The manual doesn't specify.
Post edited by Danny Tse on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Interesting
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • thuffman03
    thuffman03 Posts: 1,325
    Very interesting. Too bad I don't have an iPod.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Danny Tse
    thuffman03 wrote: »
    According to the owner's manual, you can connect an external source (i.e. CD player) to the unit. It even has a subwoofer output and a detachable power cord (in case you want to use an after-market power cord :D ).
    heiney9 Posts: 25,497
    Shipping is a little steep for a business and almost $22. Still I will do some more research, what a great little idea.
    Danny Tse wrote: »
    I wish it had external hook up for a small set of speakers.
  • Face
    Face Posts: 14,340
    If I were to guess, I'd say EL84's.
    http://audiovox2.info/docs/ar_hd/man/AV100C_DOC_OM.PDF
  • coolsax
    coolsax Posts: 1,826
    very interesting.. this might make a great work or living room radio especially since i'm getting an ipod touch for xmas, however the 10% THD is a bit rough and only 10wpc
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
    It's made by Audiovox and I have found nothing about the tubes, even the manual only calls attention to the "power outout tube viewing window". I doubt very much those are output tubes
    Here's a copy of the owners manual
    http://audiovox2.info/docs/ar_hd/man/AV100B_DOC_OM.PDF
  • bigaudiofanatic
    coolsax wrote: »
    10 watts coming from a tube is a bit of good power. Do not underestimate them.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    Overstock says it comes with a 10year manufacturer's warranty!!!! That's gotta be a typo. I might pick one of these up for the bedroom.
  • George Grand
    George Grand Posts: 12,256
    I can't believe what Acoustic Research has been reduced to.
    mhardy6647 Posts: 35,229
    It's just a name now, George, like KLH and Admiral and RCA and...
    As to the amp; probably a class AB analog chipamp output and a tube buffer between the line level inputs and the power amp. The alternative would be some Russian or Chinese surplus TV pentode being used as an audio output.
    scarf wrote: »
    can ipods play lossless audio? i would only consider buying one if they could.
    Yes.
