XPA-3 Interconnect Cables
math wizard
math wizard Posts: 106
edited December 2009 in Electronics
What type of cable would be best to connect my AVR/Prepro to this amplifier? Would digital audio cables be the best (see link) or standard Analog RCA audio cables? Is there any advantage/disadvantage to using one type over the other?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
Post edited by math wizard on
  • concealer404
    concealer404 Posts: 7,440
    Well, your amplifier accepts an analog signal because there isn't a DAC onboard.
    So... Analog. :)
  • math wizard
    Can the digital audio cables be used?
    CD - Emotiva ERC-1
    Sub - Epik Knight
    PVR - DirecTV C61k
  • math wizard
    xcapri79 wrote: »
    Yes as long as the digital audio cables are made with copper wire and are not an optical digital audio cable.
    The Monoprice cables that you referenced in your link should work just fine.
    In general, a digital coaxial audio cable is of better construction and has higher tolerances compared with analog coaxial audio cable from the same manufacturer. The performance difference between the two increase as they get longer.
    The following article should be of interest.
    http://forum.ecoustics.com/bbs/messages/34579/125179.html
    CD - Emotiva ERC-1
    Sub - Epik Knight
    PVR - DirecTV C61k
    F1nut Posts: 51,997
    Analog, period.
  • math wizard
    One says digital and one says analog. Is there any other advice out there?
    CD - Emotiva ERC-1
    Sub - Epik Knight
    PVR - DirecTV C61k
    F1nut Posts: 51,997
    Correction, two members said analog. Only one troll said digital.
  • WilliamM2
    WilliamM2 Posts: 4,808
    Digital cable is just a 75 ohm coax cable. It will work for digital or analog signals.
    What some seem to be ignoring, is that even cables labeled "analog" are often 75 ohm as well.
