XPA-3 Interconnect Cables
math wizard
What type of cable would be best to connect my AVR/Prepro to this amplifier? Would digital audio cables be the best (see link) or standard Analog RCA audio cables? Is there any advantage/disadvantage to using one type over the other?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
CD - Emotiva ERC-1
Sub - Epik Knight
PVR - DirecTV C61k
Post edited by math wizard on
math wizard wrote: »What type of cable would be best to connect my AVR/Prepro to this amplifier? Would digital audio cables be the best (see link) or standard Analog RCA audio cables? Is there any advantage/disadvantage to using one type over the other?
Well, your amplifier accepts an analog signal because there isn't a DAC onboard.
So... Analog.
Can the digital audio cables be used?Processor - Emotiva UMC-200
CD - Emotiva ERC-1
Sub - Epik Knight
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub -
Yes as long as the digital audio cables are made with copper wire and are not an optical digital audio cable.
The Monoprice cables that you referenced in your link should work just fine.
In general, a digital coaxial audio cable is of better construction and has higher tolerances compared with analog coaxial audio cable from the same manufacturer. The performance difference between the two increase as they get longer.
The following article should be of interest.
http://forum.ecoustics.com/bbs/messages/34579/125179.html
ThanksProcessor - Emotiva UMC-200
CD - Emotiva ERC-1
Sub - Epik Knight
PVR - DirecTV C61k
Analog, period.Political Correctness'.........defined
President of Club Polk -
One says digital and one says analog. Is there any other advice out there?Processor - Emotiva UMC-200
CD - Emotiva ERC-1
Sub - Epik Knight
PVR - DirecTV C61k
Correction, two members said analog. Only one troll said digital.Political Correctness'.........defined
math wizard wrote: »One says digital and one says analog. Is there any other advice out there?
Digital cable is just a 75 ohm coax cable. It will work for digital or analog signals.
What some seem to be ignoring, is that even cables labeled "analog" are often 75 ohm as well.
