Just finished my DIY acoustic corner panels
Stew
Stew Posts: 645
edited December 2009 in DIY, Mods & Tweaks
Our new basement had a really nasty snap echo in one end that was really **** up the sound of my SDA's. There is a boxed in support beam that creates a small rectangular area in the ceiling as seen in the attached pictures. It was annoying to talk in this end of the room much less listen to music.
I found a product called Corner Busters (http://www.echobusters.com/cornerbusters.html) that claims to correct such problems. I temporarily stuck throw pillows in the corners just to see if this would work and sure enough the pillows helped. The Corner Busters seemed like the ticket but they are $190 plus s/h for a 4 pack!
Plan B - I found a company called ATS Acoustics (atsacoustics.com) that sells all the stuff you need to make your own. I bought a sheet of 1" thick Owens Corning 705 for $18.80 + $9.94 shipping = $28.74. The local fabric store had a good selection of canvas and I picked up 2 yards for around $15. Home Depot had 3m Super 77 spray adhesive for around $14. I built 4 for less than $60! Owens Corning 703 is cheaper and it may have been just as good but I only needed one sheet.
They work - No more echo!!!! The annoying mid/hi frequency echo is gone and the bass sounds much tighter.
SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605
Post edited by Stew on
  • Ricardo
    Ricardo Posts: 10,634
    edited August 2008
    Nice job; they look great!!!
    SOPA
  • Systems
    Systems Posts: 14,872
    edited August 2008
    Nice work Stew.Have you thought of building some panels for the side walls.Those SDA's might benfit from having some absorbtion at the first reflection points.
    Testing
    Testing
    Testing
  • engtaz
    engtaz Posts: 7,672
    edited August 2008
    Very nice job. Congrats
    engtaz
    engtaz
  • Stew
    Stew Posts: 645
    edited August 2008
    GV#27 wrote: »
    I've thought about making one for the right side wall. It's 3' from the speaker where the left side wall is 6-1/2' from the speaker. The imaging sounds bigger on the left side and I've wondered if a panel on the right would help.
    We haven't hung up pictures in our new house yet and my wife has a tapestry from Thomas Kinkade that I like. If I can talk her out of it, I might hang it on the right wall and put an acoustic panel behind it. A 2' x2' x 2" panel would fit. Do you think that would be large enough?
    1000VA Dreadnought
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    Nice now all you need is a bigger tv
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • Systems
    edited August 2008
    Stew wrote: »
    That should certainly help and it should be 3-4" thick, just use a few layers of OC703.That right speaker does look abit close to the wall which will be acting like a big reflector.For maximum SDA effect reflections in the 200-1000hz range should be minimized.
    Testing
    Testing
    Testing
  • Stew
    Stew Posts: 645
    edited August 2008
    Thanks GV - I'll give that a try. I stacked pillows on top of the couch just to see if it makes a difference. It does open up the soundstage on that side a bit. Acoustic panels should work much better.
    Some of the web sites that sell acoustic panels also show panels behind the speakers and on the rear wall. I don't want to get carried away but just curious how much that really helps. It seems like couches, pillows, etc. would address reflections to some extent. Does it really help a lot to have that many panels?
    1000VA Dreadnought
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    I have to step up, and treat my room. I know that I need it it bad. I have some pretty big peaks, and I know the answer. I wish ridged fiberglass was available locally:(
    Looks good. Do you know the mirror trick to figure out sound reflections?
    Ben
    Ben
  • Systems
    edited August 2008
    Stew wrote: »
    For me the biggest improvement was brought about when I placed panels at each side wall first reflection point and the upper rear wall and rear corners.I tried some big panels directly behind the spreakers but I did not find them to make any difference.Like you I had a slap echo problem. I was able to control it by adding corner traps in the upper half of the rear corners and 2 panels across the back wall.Adding bass traps in any of the rooms corners should be benificial and I plan to build a pair soon.
    They will.
    The more lively and reflective the room(ie sparsely furnished,bare hardwood floors) the greater the need for more absorbtion to be added.
    Testing
    Testing
    Testing
  • Stew
    Stew Posts: 645
    edited August 2008
    ben62670 wrote: »
    Ben - I do not. How does it work?
    1000VA Dreadnought
  • Systems
    edited August 2008
    ben62670 wrote: »
    Mineral wool works just as well but as its not rigid you will need to build a wood frame.look for the ROXUL brand.
    Testing
    Testing
    Testing
  • Stew
    Stew Posts: 645
    edited August 2008
    Lasareath wrote: »
    Very nice job Stew!
    I have ATS acoustic panels in my listening room. But I have no space to make my own so I just bought their panels.
    Thanks Sal! I'm not sure I could make them much cheaper than ATS sells them. I didn't see any corner panels on their web site so I made these. If I decide to go with flat panels, I may buy some already made from ATS as well.
    1000VA Dreadnought
  • ben62670
    edited August 2008
    From your listening position have someone take a mirror, and hold it near flat against the walls. When you can see your teeters in the mirror you have found the primary reflection point;) Thats where the biggest HF reduction can be made.
    Ben
    Ben
  • ben62670
    edited August 2008
    GV#27 wrote: »
    Will do. Thanks again GV. I have my pre running now:)
    Ben
  • Systems
    edited August 2008
    ben62670 wrote: »
    Great I just checked that thread.Fun stuff eh;)
    Testing
    Testing
    Testing
  • Stew
    Stew Posts: 645
    edited August 2008
    ben62670 wrote: »
    Ben
    Thanks Ben - I'll try that today.
    1000VA Dreadnought
  • agentgreen
    agentgreen Posts: 1
    Sorry to bring up an old thread, but, I just built some corner panels myself, and am having a hard time figuring out how to hang them. How did you go about doing this?
    Thanks!
  • messiah
    messiah Posts: 1,790
    Just like you would hang a painting or anything else.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • Spehoks09
    Spehoks09 Posts: 10
    dats some cool ish..why not get the interior neons and have them hooked up the same why? Just wondering.
  • concealer404
    concealer404 Posts: 7,440
    Spehoks09 wrote: »
    Right on! RICE THE BASEMENT!!!
    Reported.
