NAS hard drives
kn505
I am looking for a NAS hard drives to back up business related files and some photos, music, and whatever. The storage size should be at least 2TB and some kind of raids (just in case the hard drives fail). I have several PC desktops and laptops that need to access these files wirelessly. It would also be nice if I can access these files from a remote location (although I dont have any idea how I am doing it yet).
What do you recommend?
Hello
I'm using this one:
http://www.netgear.com/Products/Storage/ReadyNASNVPlus/RND4250.aspx
Have had good luck with it so far, and theres a remote access option built into the software. I have it hooked into my router, and can access it just fine wirelessly through our laptop.Testing
Testing
Testing -
Thanks Lorthos for your suggestion. After checking out the Netgear, I am thinking about this one:
http://www.netgear.com/Products/Storage/ReadyNASPro/RNDP6310.aspx
Netgear is currently having a $300 rebate for it until year-end. The cheapest price I find is about $1900 shipped and before rebate.
Does anyone have experience with the one above or any other recommendation?
Thanks in advance. -
Hello
I'm using this one:
