ok to mount a csi30/40 into a wall?
I am very close to purchasing my Polk setup with RTi70s for fronts, fxi30s for rears and either a csi30 or csi40 for the center.
My question is, I'm having some in-wall shelving put in along with having my Sony Wega flush-mounted above my fireplace. I was planning on also installing the center channel above the tv and set into the wall. I was at a local hifi store and the sales guy said that would be a bad idea because the speakers were not meant to be installed in a wall. He said it would it could end up sounding hollow.
I know there are a lot of experts (or at least folks who've looked at this kind of thing before) here so I am in need of a second opinion. Am I ok to set the center speaker into the wall, or should I mount it externally?
Thanks.....
Thanks.....
Post edited by Duffman on
It probably would echo in that self.. i'd say use a tv wall mount and hook it up like that so it would be just above the tv so the sound would sound like its coming from the screen.. If ya have to mount it from the ceiling.. whatever it takes to make it flush to the top of the tv... or you could do it right below the tv if the tv is high enough.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family! -
The salesman is correct, ideally you want it mounted externally but having the center on a shelf against a wall is only fractionally better than having it in the wall. It likely wont sound horrible and it will look better in the wall. My uncle has done this with his PSBs and it sounds ok to me.Graham
I agreeLife without music would♭ -
I have a friend with the CS400i wallmounted as his rear center (CS1000P up front). He used two of the the Omnimount 20 pound wall brackets. It works great for him.
I know the CSi30 is small and lightweight enough to mount.... I can't speak for the larger models. As long as the mount is rated for the weight, and fits it, there should be no problem. Use a stud.
Here is a mount I am going to order later for my CSi30:
http://www.electroshops.com/images/wallmounts/vlb200.jpgCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
That mount looks perfect! Looks like I'll go with that one...
thanks for the replies... -
Wherever you mount it, I HIGHLY recommend the CSi40 as a center instead of the CSi30 for a well-matched front soundstage, and I know many others on this forum would agree.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
I would also go with the CSi40 for the center. If you do, the mount I suggested will not fit, and you will most likely have to go with the shelf idea. Good luck.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
