Speaker Stand top plate > Too small for my 38s?
I have a question regarding speaker stands:
I am ordering a set of Wood Technology FGH-36 stands to place my RTi38 rear speakers on. These stands are 36" tall with a 4 1/2" square top plate. A larger 8 1/2" square top plate is also available.
The RTi38 measures 8 1/2"W x 12 1/2"D. Do you think these speakers will fit on the standard 4 1/2" top plates, or do I really need to order the larger 8 1/2" plates?
Thanks,
Ron
Thanks,
Ron
2-Channel Audio
Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
Onkyo ... M-282 . ... Power Amps .(Pair)
Onkyo ... C-7030 . _.CD Player
Polk . . *. RTi A7 - ....Front Speakers
Polk . . *. RTi A3 - ....Rear Speakers
Post edited by Turbota on
Hey Ron,
I wouldn't put 38s on stands with 4.5 " plates, the speaker is almost 3 times deeper than the plate. I say go for the 8.5" plate or make your own plates.Graham -
Thanks 'gat'
Thats what I pretty much thought too.2-Channel Audio
Polk . . *. RTi A3 - ....Rear Speakers -
I concur, get the larger plate, its a safer bet.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
May I ask where you are ordering from? I was looking at the metal stands from the same company for my 38's but I didn't like the small plate.
Where can you get a larger plate from? -
I ordered them through crutchfield. Check out the link below. It tells you how to get the larger top plates:
http://www.crutchfield.com/cgi-bin/S-SGH98YII4lV/ProdView.asp?a=0&s=0&cc=01&g=15810&id=detailed_info&i=188FG36K
QUOTE: "Optional Larger Top Plate: The included assembly instruction sheet contains an offer from Wood Technology for a pair of 8-1/2" square top plates for those speakers with width and/or depth dimensions of between 8-1/2" and 11". The cost is $14.95/pair including shipping and handling".2-Channel Audio
