speaker wire questions
domflane
domflane Posts: 653
Sorry to bring up an old subject, but I have some specific questions. I'm pretty new to this and I haven't had the opportunity or the money to try out lots of different gear, so I figured I'd check with the pros:
1st - Right now I'm using 12ga speaker wire to my mains. It's Acoustic Research cable that I got pretty cheap from parts express. I have 18 ga going to the rears and 14 ga for the front. Is this stuff any good? Do you recommend different sizes?
2nd - I don't have any terminations on the ends, they're connected with bare wire. I've heard that this offers good sound, but are banana plugs better? I don't know how to solder, so are the set screw ones any good?
3rd - I just bought a subwoofer cable from monoprice, it will replace the monster composite video cable that I've been using, any thoughts on this?
Thanks in advance guys, I feel pretty good about the direction I'm going with my electronics and speakers, but I really have no clue when it comes to the cables, so any help or advice will be greatly appreciated. I don't have a ton of money for this, so I won't be getting MIT's anytime soon, unless I win the free drawing they're having on their website. Thanks again,
- Dominic
RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited December 2009
    1. Their are many ways to look at this. Personally I think a good 12 or 10 gauge wire going to all your speakers is fine. Of cores others say differently.
    2.If you feel that you will be taking your wires on and off a lot of you just want a cleaner look than get bananas.
    3. As many will say their is a lot better than monster. I think wires only make your system sound better to a certain point. Also depends on your setup.Again many different looks on this.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    I would stick with the 12g you have now on the F and run at least 14g for the rest of your system, as long as the wire is of decent quality you will be OK. Bare wire is best but it is highly reccomended to "tin" the end's with some solder to keep them from oxidizing. As mentioned banana connector's are good if you are moving thing's around a lot otherwise save your cash.
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • Serendipity
    Serendipity Posts: 6,975
    You should be fine. No need for Bananna connectors unless you will be swapping gear frequently.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Knucklehead
    Knucklehead Posts: 3,602
    Great idea....If you dont want to solder you can use deoxit and treat the end of the wires.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • kawizx9r
    kawizx9r Posts: 5,150
    +1
    And once you deoxit the wire ends, make sure not to touch them with your bare fingers. Wire exposed to air is what makes speaker wire turn green the way it does (bad!) but it doesn't happen overnight. However if you live in a humid area or something it can definitely speed up the process.
    If you want, I've got a whole set of bluejeanscables spades. Toss me your address and pay the shipping for them and they're yours.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • domflane
    domflane Posts: 653
    Wow, thanks Freddy, thats really nice of you, awsome karma. Just one question, how do the spades connect to the posts on the receiver and the speakers? I'll PM you with my address. Thanks again,
    Dominic
  • kawizx9r
    NP.
    Just unscrew the binding posts enough for the spades to fit in/around the post then screw it down tightly.
    As far as your receiver goes, they might not work for it if you don't have binding posts big enough but you can just use those extra spades on another pair of speakers.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • domflane
    domflane Posts: 653
    alright, thats what i thought, thanks again. PM sent
