Behringer amps good or bad?
MANSKITO
MANSKITO Posts: 295
edited December 2009 in Electronics
I found this brand that seems to be hitting the low price points that i can swing. However i have a nasty feeling that its going to suck any of you know any thing about this brand?
http://www.behringer.com/EN/Products/A500.aspx
Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s :D
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty
Post edited by MANSKITO on
  • Face
    Face Posts: 14,340
    They're great for pro audio, not for hi-fi.
  • concealer404
    concealer404 Posts: 7,440
    It'll certainly be loud.....
  • MANSKITO
    MANSKITO Posts: 295
    I'm sorry I don't really understand the difference. Better question is will it out preform a YAMAHA RX-V463 when playing stereo music powering Monitor 60s.
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • concealer404
    Pro gear like that allows for much higher distortion levels than you want in a home setting, and are more about getting LOUD, than audiophile accurate reproduction.
    I would say, no. It wouldn't outperform your Yamaha.
    For $300, look on the used market for a nice Adcom, Carver, NAD, etc...
  • TNTsTunes
    TNTsTunes Posts: 751
    I have an EP-1500 that I use for 90hz and down. It is nice and tight with the subs I have tried with it.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    F1nut Posts: 52,002
    Pro amps = loud, but subpar sound quality. Clear enough?
  • MANSKITO
    MANSKITO Posts: 295
    thanks again club polk.
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • TNTsTunes
    X 2
    I'll only use the Behringer pro amp for subs. It's way cheaper then 4 good plate amps and seems to do a nice job for bass.
    I suppose 1400 watts for bass is loud thou...
