Music sub VS HT sub
mrbofus
Hello
Could someone please explain to me what you mean when stating that certain subs are better for music and some better for HT application?
What the diff? and will the casual listener know the difference?
Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Onkyo DX-C390 CD Changer
POLK RTI8 Mains--Cherry
the rest...in process...slowly!!
Onkyo TX SR-507 AVR
Post edited by mrbofus on
IMO, for music:
Fast, textured bass that is of high fidelity and blends nicely.
For HT:
As loud as possible but not as much attention to sound quality.
I prefer # 1.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Serendipity wrote: »IMO, for music:
For HT:
I prefer # 1.
A quality sub will do both nicely.. -
ken brydson wrote: »A quality sub will do both nicely..
+1 on what brydson says.
I am sure some entry level or mid level subs do better at one or the other but if you get into high end subs they will do great on either.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
thuffman03 wrote: »+1 on what brydson says.
Make that a +2.
But as $$ is one of the common compromises many of us have to live with and go with entry level - mid level subs we can get one that does one thing good, so we pick a priority; music/HT. By doing so if you lean to HT you generally get more usable dB at lower frequency but give up some "speed" and control. Or if you are more interested in music you loose some of the low end stuff but tend to get more accurate tone, with enough speed and control to produce the different variety of bass notes thrown at it blending with the front speakers to reproduce music, not just boom and rumble.
But a really good designed sub, sealed or ported can do both very well. -
So the HT sub is more for the "BOOM" and the music sub is better with "sound".
What might one recommend in the entry/mid range. I guess I would say more so for music and not as much HT.
Lets say under $400Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
the rest...in process...slowly!! -
So would it be a good idea to have 2 subs and a switch for back and forth? Or just get a well built music sub? Do not mean to hijack just more details into the subject at hand.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
bigaudiofanatic wrote: »So would it be a good idea to have 2 subs and a switch for back and forth? Or just get a well built music sub? Do not mean to hijack just more details into the subject at hand.
Getting two subs depending on what you're going to be listening to, assuming that they're both integrated into the same setup, is a waste of money. Take the money you'd spend on both subs, and put it towards one nice one, or continue to save for one that does both well.
mrbofus wrote:So the HT sub is more for the "BOOM" and the music sub is better with "sound".
Lets say under $400
I think you'd be able to get into the DSW Micropros at that price. The 1000 is a great music sub, but may not have satisfactory extension for movies at higher volume.
You MAY be able to get into a Mirage Omni S12 or S10 Prestige at that price point, and i've found that they're great dual-duty subs on a modest budget. The S12 leans a little more towards HT, and the S10 Prestige is a great musical sub in my experiences.
There's all kinds of stuff on the used market for that price range, though... Klipsch, Velodyne, might even be able to score an SVS.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
keep in mind almost ALL movies contain music. Most have quite a bit of it...
