Crossover upgrade?
I see some people on the forum have upgraded the crossovers in some of their speakers. Can all Polk speakers benefit from this upgrade? What's involved and what are the benefits? Should I upgrade mine?
Front: Monitor 70's
Surrounds: Monitor 40's
Surround Back: Monitor 30's
Custom TC-3000 Sub (under construction) http://www.caraudioclassifieds.org/forum/showthread.php?t=23114
Sub Amp Behringer EP-2500
Pioneer vsx-1018-ahk
Sharp Aquos 52"
Polkie for life!
Sharp Aquos 52"
Polkie for life!
Post edited by maintrain on
Check out the DIY section of the forums. There are a ton of threads about people upgrading their crossovers.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
When you take and replace components in the x-overs with higher performing components you will generally hear a difference in sound. Now getting the exact sound your looking for will take a little research and good accurate advice from the guys around here.
The short answer to your question is, yes when done properly. -
What speakers?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes, I am sure it will help. Keep in mind that you are starting with low cost speakers though, so I would stay with Dayton or Solen caps. (i.e. - some less expensive ones)
From what I can tell, they use the same caps in all their speakers (they may use electrolytic more in their less expensive speakers - but still the same brands seem to be in use)
What I take away from that is you will see a similar benefit from upgrading the crossover as you do in more expensive speakers, but you will not hear as much of a difference as they are not as weak a link in the less expensive speakers. It will still be worth doing, but I would not spend big bucks in doing it. (i.e. - I would not spend the money for sonicaps or similar brands, I would stick with the less expensive solens or daytons as mentioned)
Either way - give it a shot and let us know what you think.
Michael
BTW - Face - his sig is showing monitor (recent series) speakers.... I assume he is upgrading those.Mains.............Polk LSi15 (Cherry)
Well said Mike!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for replies. I think a little more reading is order on my part. I'll keep you posted.Front: Monitor 70's
Sharp Aquos 52"
Polkie for life! -
Do some searches on this forum and you may be all set. If you were to post more accurate information as to what you'd like to accomplish, what were are working with and budget that will help.
DO you guys think RTi10s would benefit from a xover upgrade?HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around -
I mean like would with all the added costs it REALLY be worth it? I know it was a pretty obvious question at first.HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Of course.DO you guys think RTi10s would benefit from a xover upgrade?
you might search under Rt55's as well. Ppl like them, but are some tweekes to make them better.
In those, I would definitely go with the SonicCaps on the HF, if not both.
