Doing a DIY RCM
ben62670
ben62670 Posts: 15,969
edited February 2010 in DIY, Mods & Tweaks
Well thanks to Jim Reeves for suppling the key parts which include a low rpm Gear drive motor, plater, and body. I have taken it apart, and did some measuring. The motor, friction wheel that will drive the platter:). This is a project that will end up pertty like My sda's:)(perty). Right now I have the original cover being used as the splash pan on top of the original body. I have a plastic welder that I used to weld it in place before I applied the sealer. I am going to build a wood case for it and veneer it. I may also make a hinged cover to keep it clean.
Thanks again Jim!
Ben
Ben
Post edited by ben62670 on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited December 2009
    I have linked it before but here it is again for ya http://www.teresaudio.com/haven/cleaner/cleaner.html
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • thsmith
    thsmith Posts: 6,082
    Ben, you need any Triton X-114?
  • kcoc321
    kcoc321 Posts: 1,788
    Ben, here are some drawings for a DIY cleaner that I thought incorporated some good ideas. I unfortunately didn't save the link. Enjoy :D
  • zingo
    zingo Posts: 11,258
    Bikerboy also made a good one that I have seen in action.
  • ben62670
    I think what I am going to do is skip the fluid spray, and just use a spray bottle. I have some cleaning soulution. All I need to do is hook up a vac, and build a box.
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    Have fun Ben, I'll be thinking about you everytime I hear the roar of my VPI 16.5.
  • ben62670
    I have been real busy lately(good thing). I have the motor mounted, and a "splash shield" I just need to mount a suction tube, and build a base for it.
    Ben
  • bikerboy
    bikerboy Posts: 1,235
    I finally took a photo of the diy cleaner I made. I went the simple route with a hand held vacuum wand. $6 value village vacuum under the $20 TT platter with a $35 shark steamer and a hockey puck with weather striping to spin the record. I use the AT brush and soak it with the tergitol and brush the lp clean. Steam, vacuum, scrub with tergitol, vacuum, steam, vacuum. Sure cleans up records that I would have never played before. Recorded a Gregorian Chant lp that looked nasty and now it sounds quite good. Recording at 24/192 sounds great.
    RCM.jpg 212.6K
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    I was thinking about cheating like you did with the wand;)
    Ben
  • hearingimpared
    bikerboy wrote: »
    That looks pretty cool Jeff. You are as anally crazy as me with the various steps you do.
    I particularly like that black thing on top of your turntable.;):D
    Toolfan66 Posts: 18,129
    Is that one of your clamps Joe?
    on another note that really nice Denon TT needs some cleaning:(
  • bikerboy
    Thanks to you I have a wonderful tt rig. It wouldn't sound nearly as good as it does without the Clamp. I got it a long time ago. Thanks, Joe. I have covered the underside of the platter with butyl caulking to add mass. So that and the Clamp makes the record well dampened. Now back to the recording. No time for dusting. Just finished The Sun Story by Rhino records. Nice stuff.
    Bottlehead Eros
    CD: DIY Shigaclone
  • hearingimpared
    Thanks Jeff for the kinds words that I pulled out of you! LOL!!!;):D
    Larry there's your answer.
  • hearingimpared
    bikerboy wrote: »
    Hmmm butyl caulking, interesting. I use Sorbothane sheets to cover the entire underside of my plinth. I was afraid to use it on the bottom of my platter because I thought it might throw it out of round.
  • ben62670
    I put a dynaMat type noise reducer on the under side of my TT no problems.
    Ben
  • hearingimpared
    ben62670 wrote: »
    Underneath your platter?
  • bikerboy
    The butyl is very sticky but it never hardens so you can change things if needed. Stops the platter from ringing like a bell. That and Joe's Clamp!
    Bottlehead Eros
    CD: DIY Shigaclone
    Nice!!! Is the whole clamp made of delrin?
  • hearingimpared
    The base, cap and collet bushing are 100% delrin. There are three different thickness shims that are also made of delrin. The collet is heavy brass. The spring is a rubber/sorbothane composite and there is a stainless steel pin inserted in the side at the bottom to hold the collet in place. I use and industrial grade silicone grease to lightly lubricate the cap and base left handed threads.
    There is a good picture of it here;
    http://www.polkaudio.com/forums/showpost.php?p=554640&postcount=10
    Larry give me a call. I've been meaning to speak to you about this being that you have a machine shop.
  • hearingimpared
    bikerboy wrote: »
    Jeff does that in anyway affect the balance and true spin of the platter? I've been thinking of placing Dynamat Extreme on the underside of my platter but have refrained from doing so because I am afraid that if it's not perfectly round it will throw off the balance of the platter. My platter is 1 3/4" thick and is a delrin/aluminum composite with the delrin on top. It doesn't ring but I figure I can never use too much damping on it. I also have been thinking of using Sorbothane sheets in lieu of the Dynamat E because if there is a problem, I can just peal it off where with the Dynamat E it would be very difficult to remove plus there is a thin outer layer of heavy aluminum (I believe) used as the backing.
  • bikerboy
    Hi Joe,
    I cant say I notice any change in balance. But this denon uses a speed sensor on the outer rim of the platter so it is changing speed all the time. When I spin the platter it doesnt stop at the same place. Your platter is much more dense and I doubt I would add anything to it.
    Bottlehead Eros
    CD: DIY Shigaclone
  • hearingimpared
    bikerboy wrote: »
    Hi Joe,
    Yep, I tend to agree with you.
