Will the new line work with the RTi38's and CSI40?
I'm really thinking about returning my new pair of black RTi70's for one of the new RTi models.. either 10 or 12.. most likely 10.
Anyways.. Will the new line timber match the older RTi38 for rears and the CSi40 for the cetner?
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Post edited by eclypse on
Whats wrong with your 70s? You have such a nice setup, perfectly matched.Graham
Nothing really besides looks.. Which the new line has over the old.
I just figure for 400 bucks more i'd have the newest and greatest.. Plus i hear from a few that the sound is nicer from the new line...
Other then that i'm thinkin that i wouldn't need a sub woofer sicne the 10's have a dual 7" woofer in both... That right there would make it an even trade really returning the velodyne 10" sub as well.
I'm in a condo and the sound travels below us i'm sure.
I'm not totally sure i want to do all of that yet but i know how i am if the newer ones look and sound as good as they do on the net i'm gona want them..Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
I cant blame you, it seems that you have upgradeitis as bad as the rest of us. If you want good bass, consider returning the sub, and getting bass shakers. They mount to the bottom of couches or chairs and shake. I have heard good things about them form people in apartments who want bass without getting evicted. If this interests you check out aura or buttkicker. Also try parts express.Graham
