For my Christmas stocking
NJPOLKER
NJPOLKER Posts: 3,475
edited December 2009 in The Clubhouse
I almost forgot to buy myself some things for my stocking.
Mye Sound Spikes (1/4"-20) for my SRS2's
Deluxe 1/4"-20 T-Nuts 50 per package so I'll be giving the extras away soon.
Caig DeoxIT Gold
Caig Brushes
Hot melt glue gun and sticks
Soldering Iron
That should cover miscellaneous purchases.
What other miscellaneous products should a guy have? I have plenty of Cardas solder already.
Post edited by NJPOLKER on
  • Face
    Face Posts: 14,340
    What kind of iron?
  • concealer404
    concealer404 Posts: 7,440
    Do you already have deadening feet a la Vibrapods under your components?
    BTW.. are your SDAs already spiked or not? I was completely floored with the difference spiking made. :D
  • NJPOLKER
    Face wrote: »
    What kind of iron?
    Hell I don't know. It's funny you ask about it because I had to spend an extra $5.00 to get free shipping so I bought a $15.00 soldering iron. As I remember it is a variable iron.
    I have some myrtle wood blocks under my CDP now.
    My SRS2's have stock screw adjustable feet. The Mye's should be a nice improvement. They have carpet over concrete under them now.
  • thsmith
    thsmith Posts: 6,082
    NJPOLKER wrote: »
    The myespikes will serve you well. I love mine on my SDA-1Cs.
    As you know I bought some V-caps OIMP for my Anthem Pre so I guess those will be my stocking stuffers
  • NJPOLKER
    thsmith wrote: »
    When will they be installed?
  • thsmith
    NJPOLKER wrote: »
    Hopefully Saturday, maybe Friday. I have to stain a back door so who knows.
    Can't wait.
    The Amperex 6dj8s are burning in nicely. Lastnight was the first time I really liked how they sounded. I was getting worried because I have not noticed any of my tubes sounds changing with burn in. Maybe becuase they were already burned it but first I was dissapointed with the Amperex.
  • NJPOLKER
    You have to stain a back door? Take your time and do it right. Should take maybe 45 minutes ;)
