Rti4 Speaker Stand
hikarate
Anyone use Sanus BF-31B stands with these?
http://www.amazon.com/gp/product/B00006JQ5O/ref=oss_T15_product
If not, anyone using these speakers recommend a pair of stands for < $100?
Thanks.
Thanks.
Post edited by hikarate on
I have the 24" Sansus stands I got off ebay well made and work fine.
Thanks Zarrdoss,
I believe those are rated by Sanus as small to medium, and have a 7.5x7.5 pad for the speaker, the 31b has a 5x5 pad. I'm not sure what they consider a small or medium speaker, but hoping the 31b has enough surface area to be stable with the Rti4s.
I ordered them off Amazon last night without doing enough research, so if nothing else I'll be able to comment on my results. If someone knows they won't work however, I will just pack them up and send them back. Thanks. -
A bit precarious, but they get the job done, I'm keeping them. I'd recommend a bigger speaker pad for anyone who isn't on a budget or doesn't like to gamble.
I run the Sanus nf30b-03 for my FXi A6's and they work well! They are quite solid and i like the simple yet effective implementation for cable management
If the top plate was a lil' bigger i would be happier but they were included with my speaker purchase so i didn't complain
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
very nice stands...very wide 17" base...http://www.amazon.com/Quiklok-BS300-Monitor-Speaker-Adjustable/dp/B0006Z8FTM/ref=sr_1_23?ie=UTF8&s=musical-instruments&qid=1263596060&sr=8-23
they are holding some high end B&W's...the stands are solid !!!
My Monitor 5jr's are on these stands, and they are well built stand, especially for the price. Just be sure that you will not have a problem with the base plate: it is rather small if your speaker has a large base. My monitors are probably pushing it, but I'm getting away with it cuz I don't have anyone/anything else here who could bump the stand. If that's not an issue, however, a good stand for the money.- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC
