suggest a sub?
devilish
This is what I have so far:
Yamaha RX-765
Monitor 70 for front
CS2 for center
OWM3 for surround.
which sub best suits this setup?
Room size is 16x12 feet.
Thanks!
Devilish
Yamaha RX-765
CS2 for center
OWM3 for surround.
Thanks!
Devilish
Post edited by devilish on
Micropro 1k
Honestly though, what's your budget and what kind of use will this sub see?
50/50 ht/music? Could check out a PSW505 if you're more into HT but I think in that small area the micropro would be fine plus it's an excellent sub for music.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Or just have Freddy build you one!
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
mostly HT and TV viewing. 20% music. trying to keep cost low.. adding the tv/rec/dvd is already too expensive of an upgrade
Knucklehead wrote: »O just have Freddy build you one!
I'd build him a beast of a sub. You know Chris (cstmar) loves that thing right? But that's on a whole different level
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
What's the budget you are working with?Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
~250
go with used....you will get a lot more for the money.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Knucklehead wrote: »go with used....you will get a lot more for the money.
Since I am getting the same front and center as the OP, what used subs would you suggest? I was looking at the PSW505, but if my money (and maybe the OP's too) will go further why not go used. The only thing is there are lots of brands! -
I sold my Klipsch RW-10D for around there, might have been cheaper, and i have no doubts it would make the PSW505 cry uncle.
I'll suggest my normal suggestions, and let everyone else go with the other stuff:
There's some Velodyne subs in that realm on the used market, but i'm not familiar with their models.
Klipsch RW-10D
Mirage Omni S10/S12
I've heard the above, owned the above, and they're very capable for that price point.
What size room are you trying to fill, though?I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Do the DSW micro/regular series make sense to pair with the monitor 70/CS2 or is the PSW125 a better choice?
Mainly HT with 20% music use. -
I don't know how much power you are looking for, but this is the sub I have, and for the price ($99 new free shipping) you really can't go wrong. I'm very happy with it.
Polk Audio PSW10- this sub is also matched with the monitor series, so should integrate well with your M70's.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290034- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
A 505 would be brutal in a room that size! You can get it for $250 with free shipping, and it's new, so you get the legendary Polk CS to go with it! I love the micropro, but I think the 505 would be more your speed since it would be mostly HT:) I don't know if fry's still has that sale going on for the micropro 1000 or not, but if so, it's definitely worth a look for $270. Good luck:)Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
250 is a tight budget..with your room the PSW505 will do fine..and since you're mostly a HT man the fact that it's not the most musical of subs should present NO problem..it will be plenty loud in such a small room.....
You can also think about the Boston HPS12HO which is selling for almost nothing....and matches the PSW505 quite well...probably even a bit better. It's not a sub for finesse..it's a 300 watt/600 peak 12" that didn't sell well mostly because of its ODD appearance--and is now a discontinued model....but it can bang out HT LFEs loudly enough! It you're looking to go cheap...this might do you....
I would also recommend the PSW505, for the price it is going for these days at the egg, it is hard to beat it.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
The PSW505 is about as good as you're going to get for what you want, new.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
there is a $20 off for the PSWS505 @ newegg and combined with the paypal 10% off its turning out to be ~200. Ordered mine!
