suggest a sub?
devilish
devilish Posts: 48
This is what I have so far:
Yamaha RX-765
Monitor 70 for front
CS2 for center
OWM3 for surround.
which sub best suits this setup?
Room size is 16x12 feet.
Thanks!
Devilish
Post edited by devilish on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited December 2009
    Micropro 1k :D
    Honestly though, what's your budget and what kind of use will this sub see?
    50/50 ht/music? Could check out a PSW505 if you're more into HT but I think in that small area the micropro would be fine plus it's an excellent sub for music.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Knucklehead
    Knucklehead Posts: 3,602
    Or just have Freddy build you one! :D
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • devilish
    devilish Posts: 48
    mostly HT and TV viewing. 20% music. trying to keep cost low.. adding the tv/rec/dvd is already too expensive of an upgrade ;)
  • kawizx9r
    O just have Freddy build you one! :D
    I'd build him a beast of a sub. You know Chris (cstmar) loves that thing right? But that's on a whole different level :p
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • devilish
    devilish Posts: 48
  • Knucklehead
    go with used....you will get a lot more for the money.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • RoverRH
    RoverRH Posts: 10
    Since I am getting the same front and center as the OP, what used subs would you suggest? I was looking at the PSW505, but if my money (and maybe the OP's too) will go further why not go used. The only thing is there are lots of brands!
  • concealer404
    concealer404 Posts: 7,440
    I sold my Klipsch RW-10D for around there, might have been cheaper, and i have no doubts it would make the PSW505 cry uncle.
    I'll suggest my normal suggestions, and let everyone else go with the other stuff:
    There's some Velodyne subs in that realm on the used market, but i'm not familiar with their models.
    Klipsch RW-10D
    Mirage Omni S10/S12
    I've heard the above, owned the above, and they're very capable for that price point.
    What size room are you trying to fill, though?
  • devilish
    devilish Posts: 48
    Do the DSW micro/regular series make sense to pair with the monitor 70/CS2 or is the PSW125 a better choice?
    Mainly HT with 20% music use.
  • Zitro
    Zitro Posts: 864
    I don't know how much power you are looking for, but this is the sub I have, and for the price ($99 new free shipping) you really can't go wrong. I'm very happy with it.
    Polk Audio PSW10- this sub is also matched with the monitor series, so should integrate well with your M70's.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290034
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • rallyshark
    rallyshark Posts: 417
    A 505 would be brutal in a room that size! You can get it for $250 with free shipping, and it's new, so you get the legendary Polk CS to go with it! I love the micropro, but I think the 505 would be more your speed since it would be mostly HT:) I don't know if fry's still has that sale going on for the micropro 1000 or not, but if so, it's definitely worth a look for $270. Good luck:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
    250 is a tight budget..with your room the PSW505 will do fine..and since you're mostly a HT man the fact that it's not the most musical of subs should present NO problem..it will be plenty loud in such a small room.....
    You can also think about the Boston HPS12HO which is selling for almost nothing....and matches the PSW505 quite well...probably even a bit better. It's not a sub for finesse..it's a 300 watt/600 peak 12" that didn't sell well mostly because of its ODD appearance--and is now a discontinued model....but it can bang out HT LFEs loudly enough! It you're looking to go cheap...this might do you....
    cnh
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    I would also recommend the PSW505, for the price it is going for these days at the egg, it is hard to beat it.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • concealer404
    The PSW505 is about as good as you're going to get for what you want, new.
  • devilish
    devilish Posts: 48
    there is a $20 off for the PSWS505 @ newegg and combined with the paypal 10% off its turning out to be ~200. Ordered mine!
