Micropro questions
rallyshark
rallyshark Posts: 417
As some of you may have noticed by my retarded posts, I just acquired 2 micropro 1ks, and have a question or two. They concern the corner,mid wall, mid room, cabinet settings. What is changed when one is selected? For example: if you select "corner" does it cut/boost certain frequencies to avoid the boom effect when a sub is in a corner, what frequencies does it cut or boost? Same question goes for the other settings. I'm going to make myself paranoid until I figure this out:o Also is there a way to know they are turned off, or is one always selected? Knowing these things will help in the next few days while I'm still finalizing the placement and adjustments:) FWIW, I'm really loving the dual 1k set up so far! Any knowledge would be greatly appreciated! Thanks!
Donny
Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car?
Post edited by rallyshark on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited December 2009
    Congrats on the subs, but uhm did you read the manual?
    You can tell whether they're on or not by the blue led status indicator. Also on the rear you'll have the option to either always have it on, auto turn on (which turns the sub on when it senses a signal) or a 'always off until you turn it on manually with a remote' option.
    As far as the 'placement' settings, I never noticed a difference when switching between them. Honestly I'd say that's utilized with the 2k and up models seeing as they come with a detachable mic for better customizing.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    treitz3 Posts: 19,989
    Read the manual. Then experiment. Lots. You'll get there.
  • rallyshark
    kawizx9r wrote: »
    Sorry, I should have clarified my question a little more. I was referring to the settings of "corner,mid room etc. being on, if there is a setting in which none of those settings are applied. It does the different blinks of the light to show which setting is applied when you press it on the remote, but there is no option for none. Does that make more sense? I leave it to auto detect to come on, so I understand that part:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • kawizx9r
    Yea, that too is what I was talking about IE mid wall/corner/etc.
    I noticed no changes when cycling through each one.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • rallyshark
    Yeah, I can't tell much difference to the settings either, but I'm not used to the sub yet, and figured I just have a bad ear:confused:
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I think what he's asking, is whether or not there is an option to turn off all of the various EQ settings(corner, mid-wall etc.), and run it without the internal room optimization.
    I don't have any MicroPro's...so I'm not sure. I'm considering going with either dual 1000's or 2000's when I upgrade my sub though. Dual Epik Vanquishs or Sentinels are high up on the list too.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • rallyshark
    Thanks curt! That's exactly what I was trying to figure out:) I suck at putting things into written word:o FWIW, I'm loving the dual micropro1k set up! I have hardwood floors, and they are almost like tactile transducers. It's like getting a massage every time I watch a movie:D
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • Squishy Tia
    Squishy Tia Posts: 79
    I believe the MicroPro series defaults to a phase 0°, Cabinet, volume 20 setting when reset to their defaults using the remote. I too would actually have liked a "kill all EQ" setting so my AVR's autosetup could more easily calibrate the sub with the other speakers. Many people have noted that Audyssey or YPAO equipped AVRs are actually better at setting up the sub than the sub itself. I too found this to be true on my MP4K, as the sub's auto setup actually muffled the bass in about four different frequency ranges, really making it sound unnatural.
