What Gauge is this Speaker Wire?
Monster Cable Navajo White Mini-Spool Speaker Cable model number XPNWMS100. It can be bought at Circuit City and Best Buy but I didn't see the gauge size anywhere.
Does anyone know if this would be sufficient to use with Polk RM7200 with PSW550 sub?
Thank you!
Robert
Thank you!
Robert
Post edited by gyver65 on
14 gauge - yes"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Thanks Shack!
Would this provide sufficient sound while listening to SACD and DVD-Audio?
My DVD player is a Pioneer DV-563A.
Thanks! -
Sorry dont mean to high jack your thread but i've been meaning to ask the same question..
I recently bought up 3 100' spools of Monster XPHP-CI (CL3-rated jacket for in-wall use)
Anyone know the gauge?
I need it for long runs of 35'+ for my rear channel which is RTi38s and FXi30 if i can find them..
I'm planing on using them as well for the fronts (RTI70s) and center (CSI40)
I never liked how Monster cant tell you the gauge!Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
I believe that Monster XP is 16 gauge while Monster XPHP is 14 gauge.My 7.1 setup consists of:
Denon 3803
Panasonic DVD
RTi70s front
CSi40 front center
RTi28s side surround
FXi30s back surround
PSW202 Subwoofer - Hey, it's my first sub!
RCA 46" 4:3 RPTV -
No i own the XP monster white wire stuff and its clearly 14 gauge.. I just tested it with a wire cutter.. Also my XPHP stuff is 12...
Like doh! hehe i guess i didnt think i could check it myself..
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
