Need Advice: Melos Tube Hybrid Preamp MA-111
dpowell
dpowell Posts: 3,081
edited December 2009 in Electronics
Local seller in San Diego is offering a Melos Tube Hybrid Preamp MA-111 for $580. I know there is a difference between a straight tube pre and a hybrid but I don't know what those differences are. I'm just keeping my eyes open for an entry into a tubed pre which will replace my B&K Ref 10 pre. Any thoughts appreciated.
Post edited by dpowell on
    heiney9 Posts: 25,518
    A pre-amp just like a power amp has input stage (front end) and output stage (back end) circuitry so my guess is one or the other is transistor based and one is tube based. If I had to guess (a total guess) I'd say the input is either tube or tube buffered and the output stage is transistor.
    But then again it could be the opposite and have a tube buffered output like many tube cdp's
    Google give you any results?
  • dpowell
    I'll keep googling to see if I can figure it out. I also saw a Musical Fidelity X10-D Tube Buffer that goes in between the CDP and the pre for $130. Does a good tubed preamp accomplish the same thing except with one less set of interconnects?
    dpowell wrote: »
    A good tubed pre-amp is much better than a buffer for the reason you mention and many others.
    How many tubes in the Melos and where are they physically located and what tubes are they? Sometimes that info can help.
  • george daniel
    george daniel Posts: 12,096
    Melos made very good gear in their day.It's been my experience with Melos gear that the SHA Gold(if you want a remote) or an SHA 1(no remote) make very good pre amps,and both have very respectable headphone circuits,and have quite a following in other circles.The SHA series use the popular 6DJ8 and varients,I do not know much about yours except that it was made in 89 IIRC. I think that you will be happier with a tubed pre as opposed to a tube buffer,YMMV--good luck.
  • dpowell
    Thanks, I just saw a Sonic Frontier's SFL-1 hybrid pre on Audiogon. It appears to have 1 tube and I'm guessing this Melos would be the same. I'll just wait on a tubed pre, especially since those can be had for not too much more than the asking on this.
    Chances are if it's a single tube it's at the output and then it's just "buffered" rather than a full blown tube circuit.
    Best to wait for a full tubed pre-amp; in the long run you'll be more content.
  • george daniel
    dpowell wrote: »
    The Melos Sha 1 has two tubes, people who own them tend to hang on to them,but you can find em for sale (stock and modded) at headfi quite often.
    Good luck in your search.
  • i have a Melos MA-111 pre amp I got from a friend with the power cablw/supply missing. is there anywhwere to find one?
  • invalid
    invalid Posts: 1,531
    heiney9 wrote: »
    Actually a tube preamp can use a single dual triode on the input stage.
    F1nut Posts: 52,011
    kejamill wrote: »
    https://www.ebay.com/itm/236299820691?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=dpy7jja_sv2&sssrc=4429486&ssuid=&stype=1&var=&widget_ver=artemis&media=MORE
