Termites Vs. Sid
VR3
previous, inactive termite damage.... vs... ME! hahha
Thanks to Russ and my buddy Nick -- we have rebuilt the entire rear of the house!
Post edited by VR3 on
Wow. That's pretty hardcore.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Watch out. They do have you outnumbered!"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
Good job Trey
why didnt you just buy land and build a new house?? hahaha.
Awesome work man.
There's nothing like during it yourself.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Trey, is that loose fill insulation on the floor? Regardless, I hope you have been wearing a filter mask.
Very nice work! Good luck on the remodeling.:)Carl -
thanks guys! i take alot of pride in what i do and wanted to make sure what i put in will last as long as it has so far... one thing i did that russ turned me on to is square bit composite screws - made the jjob a piece of cake. i did wear a dust mask. hopefully by tomorrow that room will be ready for insulation.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey your the Man!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Vr3MxStyler2k3 wrote: »thanks guys! i take alot of pride in what i do and wanted to make sure what i put in will last as long as it has so far... one thing i did that russ turned me on to is square bit composite screws - made the jjob a piece of cake. i did wear a dust mask. hopefully by tomorrow that room will be ready for insulation.
You ought to try torx bit screws, even better....Testing
Testing
Testing -
Very impressive Trey.
Up here we call square screw heads Robertsons.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
One thing raised a concern with me. It appears certain areas that have insulation installed have the vapor barrier installed (kraft paper) You then applied a plastic vapor barrier over that. I've read that a double vapor barrier is not adviseable. I'm under the impression that the kraft paper needs to be scored with a razor and then the plastic is acceptable. Could be wrong on this but I'd look into it before the rock goes up.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Might as well take down a few more 2x4's and build a completely new house.
Vinyl, the final frontier...
Thanks for the comments guys!
Sal - wait until you see the Ehternet and HDMI connections on that wall, you might go crazy in your seat! haha
We will be able to link two computers to a TV in the room over HDMI, link one to the den TV -- all kinds of ethernet connections for gaming and the works - very exciting.
Thanks for the advice on the vapor barrier - I will look into that for sure!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The poly vapor/moisture barrier will stop anything from reaching the paper faced fiberglass and do a much better job anyway. Have you used Dursban or some other termiticide to treat the soil on BOTH sides of your foundation?? It'd be a good idea while everything is unfinished. (smells bad!):)
Here are some crappy cell phone pics...
Pretty much all stud work is done except for one at the end of that closet wall...
Pretty much rebuilt that corner of the house... -- bottom plates were added for additional sheetrock security...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
