Termites Vs. Sid
VR3
VR3 Posts: 29,384
edited December 2009 in The Clubhouse
previous, inactive termite damage.... vs... ME! hahha
Thanks to Russ and my buddy Nick -- we have rebuilt the entire rear of the house!
Post edited by VR3 on
  • audiobliss
    audiobliss Posts: 12,518
    Wow. That's pretty hardcore.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • sucks2beme
    sucks2beme Posts: 5,680
    Watch out. They do have you outnumbered!
  • Fireman32
    Fireman32 Posts: 4,845
  • exalted512
    exalted512 Posts: 10,735
    why didnt you just buy land and build a new house?? hahaha.
    Awesome work man.
    -Cody
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    There's nothing like during it yourself.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • schwarcw
    schwarcw Posts: 7,357
    Trey, is that loose fill insulation on the floor? Regardless, I hope you have been wearing a filter mask.
    Very nice work! Good luck on the remodeling.:)
    Carl
    VR3 Posts: 29,384
    thanks guys! i take alot of pride in what i do and wanted to make sure what i put in will last as long as it has so far... one thing i did that russ turned me on to is square bit composite screws - made the jjob a piece of cake. i did wear a dust mask. hopefully by tomorrow that room will be ready for insulation.
  • danz1906
    danz1906 Posts: 5,144
    Trey your the Man!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Systems
    Systems Posts: 14,873
    You ought to try torx bit screws, even better....
    Testing
    Testing
    Testing
  • hearingimpared
    hearingimpared Posts: 21,136
    Very impressive Trey.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    Up here we call square screw heads Robertsons.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Hawkeye
    Hawkeye Posts: 1,313
    One thing raised a concern with me. It appears certain areas that have insulation installed have the vapor barrier installed (kraft paper) You then applied a plastic vapor barrier over that. I've read that a double vapor barrier is not adviseable. I'm under the impression that the kraft paper needs to be scored with a razor and then the plastic is acceptable. Could be wrong on this but I'd look into it before the rock goes up.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • madmax
    madmax Posts: 12,434
    Might as well take down a few more 2x4's and build a completely new house. :)
    Vinyl, the final frontier...
    VR3 Posts: 29,384
    Thanks for the comments guys!
    Sal - wait until you see the Ehternet and HDMI connections on that wall, you might go crazy in your seat! haha
    We will be able to link two computers to a TV in the room over HDMI, link one to the den TV -- all kinds of ethernet connections for gaming and the works - very exciting.
    Thanks for the advice on the vapor barrier - I will look into that for sure!
  • gdb
    gdb Posts: 6,012
    The poly vapor/moisture barrier will stop anything from reaching the paper faced fiberglass and do a much better job anyway. Have you used Dursban or some other termiticide to treat the soil on BOTH sides of your foundation?? It'd be a good idea while everything is unfinished. (smells bad!):)
    VR3 Posts: 29,384
    Here are some crappy cell phone pics...
    Pretty much all stud work is done except for one at the end of that closet wall...
    Pretty much rebuilt that corner of the house... -- bottom plates were added for additional sheetrock security...
