What Gauge is this Speaker Wire?
gyver65
gyver65 Posts: 13
edited October 2003 in Speakers
Monster Cable Navajo White Mini-Spool Speaker Cable model number XPNWMS100. It can be bought at Circuit City and Best Buy but I didn't see the gauge size anywhere.
Does anyone know if this would be sufficient to use with Polk RM7200 with PSW550 sub?
Thank you!
Robert
Post edited by gyver65 on
  • shack
    shack Posts: 11,154
    edited October 2003
    14 gauge - yes
  • gyver65
    gyver65 Posts: 13
    edited October 2003
    Thanks Shack!
    Would this provide sufficient sound while listening to SACD and DVD-Audio?
    My DVD player is a Pioneer DV-563A.
    Thanks!
  • eclypse
    eclypse Posts: 595
    edited October 2003
    Sorry dont mean to high jack your thread but i've been meaning to ask the same question..
    I recently bought up 3 100' spools of Monster XPHP-CI (CL3-rated jacket for in-wall use)
    Anyone know the gauge?
    I need it for long runs of 35'+ for my rear channel which is RTi38s and FXi30 if i can find them..
    I'm planing on using them as well for the fronts (RTI70s) and center (CSI40)
    I never liked how Monster cant tell you the gauge!
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • jkratzer
    jkratzer Posts: 148
    edited October 2003
    I believe that Monster XP is 16 gauge while Monster XPHP is 14 gauge.
    My 7.1 setup consists of:
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RTi28s side surround
    FXi30s back surround
    PSW202 Subwoofer - Hey, it's my first sub!
    RCA 46" 4:3 RPTV
  • eclypse
    eclypse Posts: 595
    edited October 2003
    No i own the XP monster white wire stuff and its clearly 14 gauge.. I just tested it with a wire cutter.. Also my XPHP stuff is 12...
    Like doh! hehe i guess i didnt think i could check it myself.. :o
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
