Quick Amp question
Pycroft
Pycroft Posts: 1,961
edited December 2009 in Electronics
Does an amp have to say that it can handle a 6 ohm load to power them? For instance, my Soundcraftsmen amp is rated at 205 watts for 8 ohms, and I believe 325 watts for 4 ohm. It says nothing about 6. I'm assuming if it can handle 4 ohms, it can handle 6, correct?
Thanks.
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
    heiney9 Posts: 25,498
    Yes.....
  • steveinaz
    steveinaz Posts: 19,546
    Yep, that Soundcraftsmen will power just about anything. Remember, speaker impedance ratings are "nominal" which means an impedance of 8 ohms is just an average over the frequency band for that speaker.
  • steveinaz
    To better illustrate, here's a Paradigm Ref Studio 60, rated nominally at 8ohms, note how impedance shifts with differing frequencies (solid trace). This one sweeps from 3ohms minimal (@ 200Hz) to a max of 23ohms (@ 75Hz):
  • Pycroft
    I'm not sure I understand that. It's okay though, not all is meant to be understood. George says he know what people would say...well let's see.
    What would be better to power SDA 1C's - the Soundcraftsmen PCR800 OR a B&K ST-140. Anyone have experience with either of these amps actually powering these speakers?
    2 Channel/HT:
    Harman Kardon HK354
    Sony SACD Player
