Quick Amp question
Pycroft
Does an amp have to say that it can handle a 6 ohm load to power them? For instance, my Soundcraftsmen amp is rated at 205 watts for 8 ohms, and I believe 325 watts for 4 ohm. It says nothing about 6. I'm assuming if it can handle 4 ohms, it can handle 6, correct?
Thanks.
James
Thanks.
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
Yes....."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Yep, that Soundcraftsmen will power just about anything. Remember, speaker impedance ratings are "nominal" which means an impedance of 8 ohms is just an average over the frequency band for that speaker.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
To better illustrate, here's a Paradigm Ref Studio 60, rated nominally at 8ohms, note how impedance shifts with differing frequencies (solid trace). This one sweeps from 3ohms minimal (@ 200Hz) to a max of 23ohms (@ 75Hz):Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I'm not sure I understand that. It's okay though, not all is meant to be understood. George says he know what people would say...well let's see.
What would be better to power SDA 1C's - the Soundcraftsmen PCR800 OR a B&K ST-140. Anyone have experience with either of these amps actually powering these speakers?
Thanks2 Channel/HT:
Harman Kardon HK354
Sony SACD Player
