Not to smart with electronics
spudster9904
I Just upgraded my tv to a 46'Sony Bravia that came with a sony blue ray disc/dvd player. I had went to American TV store and listened to some polk audio speakers that sounded great. I really don't understand the 5.1 channel and the 7.1 channel. What is the difference. Also was is the best receiver to go with it. I also need to hook up a WII system to it. Any sugestions?
Post edited by spudster9904 on
5.1 channels mean 2 front speakers + 1 center speaker + 2 surround speakers + 1 subwoofer
7.1 channels mean 2 front speakers + 1 center speaker + 2 surround speakers + 2 rear speakers + 1 subwoofer
You select either 5.1 or 7.1 setup depending on the allowance of your listening environment (room size - seating locations - speaker locations) as well as your pocket allowance
About the AVR, you should go with one that supports HDMI input/output and lossless audio. Let the guys know which speakers you are gonna get and they will suggest on which AVR to go with.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
That sums it up pretty much...keep in mind MOST movies are still only 5.1. If you get a 7.1 AVR you can always add speakers down the road, or use the 2nd zone for your deck, balcony or whatever. Welcome to CP!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
If you are playing blu rays most of the newer movies are 7.1 surround. They say that it allows you to have a more in depth audio experience with the movies. Personally I can go with 7.1 but have not yet because I do not have enough cash for the side speakers.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
bigaudiofanatic wrote: »If you are playing blu rays most of the newer movies are 7.1 surround.
I don't know about this claim. Mostly I saw 5.1 as the norm.Gears shared to both living room & bedroom:
Living room:
Bedroom:
Other rooms:
Thats what I was thinking.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Unless your room is big enough, and set up just right, 5.1 might still be the better option."They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
I have also seen very limited numbers of movies (Blu-Rays) that are formated in 7.1, Almost all of them are still in 5.1. The switch to 7.1 may come in the future, but probably not for awhile and will happen gradually, IMHO. You can still get a 7.1 AVR and be ready when the time comes, as suggested above. I agree 1000% with Christopher (Messiah) if you don't have the room for a 7.1 setup, you will gain nothing by trying to cram an extra 2 speakers in there, IMHO it would only make it sound worse. A properly setup 5.1 system will sound much better than a cramped up 7.1. Welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
x3 or maybe 4? fact is very few content support 7.1 yet.I don't know about this claim. Mostly I saw 5.1 as the norm.
Some factors to consider...Unless your room is big enough, and set up just right, 5.1 might still be the better option.
I agree that if your budget allows you you should be getting the 7.1 to be as future proof as possible with your gear. As far as 5.1 versus 7.1 if room is small as far as I am concerned, this would apply for larger speakers (IE: towers) were placement might be of a problem. I personally believe that when talking about HT (nothing to do with music rig), I feel you are better of with many small speakers than only a few large ones as it fills the room much better thus giving a better feeling of realism. Having more speakers layed out across the room will also allow you to keep the volume lower for the same loudness thus easier in the receiver. This might not be shared by everyone but is simply my own opinion.wutadumsn23 wrote: »I have also seen very limited numbers of movies (Blu-Rays) that are formated in 7.1, Almost all of them are still in 5.1. The switch to 7.1 may come in the future, but probably not for awhile and will happen gradually, IMHO. You can still get a 7.1 AVR and be ready when the time comes, as suggested above. I agree 1000% with Christopher (Messiah) if you don't have the room for a 7.1 setup, you will gain nothing by trying to cram an extra 2 speakers in there, IMHO it would only make it sound worse. A properly setup 5.1 system will sound much better than a cramped up 7.1. Welcome to Club Polk.
-Jeff
Cheers!
TKDARE TO SOAR:
Neat! Actually there are more than I would have suspected but what do I know, I am still hooked to HD DVD
DARE TO SOAR:
I hear ya there, brother! I have plenty of HDDVD's to scoop up before I dive into BR...but that day will come, I know.Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
When your BD day comes, maybe you can Karma those HD DVDs down my way to WinterLandI hear ya there, brother! I have plenty of HDDVD's to scoop up before I dive into BR...but that day will come, I know.
DARE TO SOAR:
Oh, I'm planning on keeping the HDDVD collection and player. My reasoning is to scoop up all the glorious HD content for them for pennies!Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
Amen to thisOh, I'm planning on keeping the HDDVD collection and player. My reasoning is to scoop up all the glorious HD content for them for pennies!
DARE TO SOAR:
Good idea. HD-DVDs are cheap nowadays.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
...when you can find themSerendipity wrote: »Good idea. HD-DVDs are cheap nowadays...
DARE TO SOAR:
