adcom rack bolts
RyanJoz
RyanJoz Posts: 116
edited December 2009 in Electronics
I recently got an Adcom 5503 amp and two of the rack mount plugs are missing. Does anyone know where they can be found at? I called Adcom and their parts provider and they said they weren't available. I would also like to know the thread size of the rack holes on the amp. If I can't find the plugs I will use button head screws in black oxide. The guys at Adcom didn't even know the thread pattern. Hopefully one of you does.
Thanks guys!
Ryan Jozwiak
"Because music was meant to be felt and heard"
polkaudio RTiA9
polkaudio RT35i
polkaudio PSW 404
HK 3370
HK FL8380
HK DVD 22
Adcom GFA 5500
Samsung 40" LCD 120 Hz
Post edited by RyanJoz on
  • unc2701
    unc2701 Posts: 3,587
    Ok, i went through the same with with a 565, and I think how I solved it was that there was another screw on the chassis that matches the thread pattern for the rack mounts. So- unscrew 'em one at a time till you find one that fits, then take it down to Home Depot/Lowes; they should have a display with a bunch of holes to test out that'll tell you what the thread pattern is.
    Backburner:Krell KAV-300i
    Toolfan66 Posts: 18,187
    10-32 thread pitch.
  • unc2701
    10-32 thread pitch.
    That's the threading for the usual rack, not the holes on the amp- they're smaller.
  • RyanJoz
    RyanJoz Posts: 116
    it's 6-24 i believe. I will check at Fastenal in the afternoon. UNC, that did work by pulling one of the existing screws from the bottom. Perfect fit. Thanks for the tip.
    Ryan Jozwiak
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    I took a guess when I was at work but after looking at my amp I think it's an 8-24 but without a thread gauge I can't say for sure. Not sure if Adcom used metric or not if so then maybe a M4.
  • RyanJoz
    RyanJoz Posts: 116
    they are 6-32. The Adcom sure drives the A9's very very nicely.
    Ryan Jozwiak
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
