Powered Sub wooker hook up question.. HELP!
I just recently bought my dream speakers which i've been wanting for years! A brand new set of Polks all around.. I added a Velodyne CHT-10 for the sub since i've heard so many good reviews of it..
Now before this i owned 3 sets of Bose that used 3 passive woofers.. those were easy to hook up. Now this powered sub is my first and there seems to be too many hook up options with line in,speaker level in and out.. i've done search after search online and i cant get my questions answered so i guess i'll have to embarris myslef and look dumb and ask..
Which way should i go? I have been using it with a sub cable connected to the sub pre out on my Kenwood 6070 to the subs left RCA input.. I've read plenty of times in lots of differenet sub woofer articles that for the most performance ya should use the speaker level connections.. Should i go that route?
I'm using brand new polk RTi70s in the front. I have them bi-wired right now though and i cant do that with the spring clips on the sub speaker ins and outs... I noticed that the Velodyne CHT-12 has the bananna plugs i wana use so i could bi-wire the fronts threw that.. I dont know if the 12" woofer would be super over kill for my new condo.. I have people living under me.
Oh the Kenwood reciever i'm using has a cross over of 80Hz for the sub. And i cant change it.
Sorry i'm kind of a newbie to some of this stuff and i've read way too many articles online that talk about this and that about sub woofers like placement and so on but they dont explain the right way to hook'em up! What exactly does a cross-over do?.. When i set it at 80 on the sub does that mean that from 80-120hz only play from my sub woofer and the rest is passed over to the fronts?
If i hook the front speakers threw the speaker level connections does that mean that my sub will only play bass from them front 2 speakers and not the center and rears?
What does RMS stand for?? I read nothing that explains what that means.. My 10" sub specs show it has a built in 150 watt RMS power amplifier but then says it has a 375 watt amplifier??
Oh and one more question that i'm sure is a major newbie no no.. but i have to ask hehe..
Sicne my Polk 70s are bi-ampable couldnt i bi-amp them using both the reciever and the powered sub woofer sicne it has speaker level out? Is that crazy sounding?? or are those out puts on the sub non powered?
Thanks!
Thanks!
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Post edited by eclypse on
First of all, welcome to the forum. You will learn a lot of good stuff here. I learn something everything. As of right now it seems that we both have the same set up. I have the same reciever, and the same front speakers and sub. What you need to do is buy a Y-adapter. You can get one at any electronics shop. Then you use a sub-cable coming out of the .1 channel in your reciever, hook it up to the single side of the Y-adapter, then connect both the other two sides of it into the L/R channels of the sub. Haven't bi-wired yet, or even thought about it. I also cannot answer your question about the bi-amping.
The crossover sets the highest frequency that the sub will play. The rest is then sent to the fronts.
RMS= root mean square. The RMS is the pure power average. If you have a sine wave representing the power, RMS would be a square wave imposed over that (sort of). When you are buying stereo equipment RMS is the important number. It is .707*peak power which gives you the average power output. I know that is kind of confusing. If you do an internet search on RMS values, it could help. It is an electrical engineering term.
Hope that helps
BG -
Eclipse, the only change to make is to unplug the sub cable and instead plug it into the CHT-10's subwoofer direct input. This completely bypasses the internal sub crossover, which isn't needed because the 6070 is already doing the crossover at 80hz.
The speaker level outs on the sub just pass through the power from the receiver, so no bi-amping would be involved. -
eclypse,
First, welcome... Glad you are liking your 70's. Very popular model 'round here, that CC and others just put into the reach of many...
Let me see if I can address a couple questions not answered yet and amplify some others...
You're nearly wired the Club Polk way. Tends to be favored here as once the sub's volume is calibrated, it puts the sub managment completely into the hands of the AVR. So you get both convenience and repeatability. Either John's or BG's suggestion puts you all the way there. Which you choose is up to you.
BG's way with the Y-connector yields an added 3 dB output, but in your condo situation you probably can't use that anyway, unless you throw a party for the neighbors. This way does require you to set your sub's filter to maximum to avoid the dreaded double filtering. John's way bypasses the filtering as he mentioned.
If an AVR has a fixed sub cross-over, 80 Hz is as good as any, and ought to be right for the 70's.
John also rightly points out that the sub would add no amplification to the speaker line levels were you to rewire that way, the "Polk way" as it's referred to often in the Club.
BTW, the Polk way does not preclude bi-wiring or amping. To do this just run the high's wire directly to the mains, while routing the lows via the sub...
Crossovers...
Most speakers utilize two or more different drivers. To avoid gaps in reproducing sound, the ones selected overlap in the frequency range they individually reproduce. But this leads to undue emphasis in the region where the overlap occurs as the two drivers output are additive. The crossover is added to the circuits to eliminate this emphasis by rolling off the highs sent to the low freq driver and the lows to the high freq driver. Designed properly for the specific drivers used, the resulting sound level pressure (SPL) through this transition area is flat.
Your sub's filter point means that it plays frequencies at that setting and below, with the frequencies above that point routed to the speaker line out connections.
As for the centers and rears, what they play will be determined by the AVR's settings. If they are set to "small" then the AVR will route information above the fixed 80 Hz set point to them. If set to "large" they would get full signal. Most would suggest setting them to small.
Oh and RMS... some here, e.g., Russ, will tell you that Watts RMS is a misnomer. And strictly speaking he is correct. An amp's output voltage differential is best characterized in RMS terms by the calc BG mentions. Some use this value in a calculation of the amp's power and call it Watts RMS. once this was a very common spec, but more often now you'll read about continuous power rating, which is a better measure of amp performance.More later,
Tour...
Vox Copuli
Wow thanks guys! Clearing this mess up for me! Nice..
One quick question i have though that would help me understand more..
Which is lower fequencies for the sub? Is it 120 or the 40? Thats about the only thing that confuses me still.. Lower is the lower number and higher is the higher one? So when the sub is pumping out those that low range its runing 40-20?
So if i set the crossover at 80 then that means anything below that 80 like 79-20 the sub plays?
Oh the sub has a bypass switch so i can turn off the subs internal filter if i need to called "subwoofer direct/internal X-over".. So if i stick with the sub woofer cable i should use that switched to "Direct"since the reciever will be forced with using its internal 80hz filter... oh wait it might only use that filter when i enable THX mode on the reciever... hmmm.. Is there anyway to verify what the recievers filter is set at besides calling Kenwood?
I'd like to try wiring the speakers straight to the sub using speaker wire and bypassing the recievers filters but if i do i'd have to turn off the sub woofer on the reciever... The prob i see with that is i dont see how any low bass from the center and rear channels being played from the sub only the fronts. In order to fix that wouldn't i need another sub for the rear channel and hook them up straight to the rears like the fronts?Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Could still use that help...
Bump..Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
hmmm.. I can only select a speaker setting on either Large or NML/THX and i cant change the speakers independantly of eachother.. Crap..
When i use the sub cable out to the sub and set all the speakers to NML/THX and switch the sub to direct my speakers kinda sound like crap.. hollow like.. I have to turned the sub up to match the volume to blend well with the speakers durring music and it just sounds wrong to me.. I dont know, maybe i just need to get used to it or something is missing.. though the speakers sound really bright and hollow..
Damnit.. The wife dont wana budge with buying a new reciever.. I could be asking for way too much after buying a new 61" Samsung DLP and new set of speakers to go along with it that i've already spent.
Though if it is possable for me to shop for a new reciever which one of these would sound great with the new Polks Rti's..
1. Denon AVR-3803
or
2. Harman Kardon AVR 525
or
3. Onkyo TX-SR800
I mostly watch movies but so far since i'm waitin forever for my new Tv to get here i've been doing nothing but listening to music..Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
I swear I tried to reply earlier... glitch, I guess
No... There's ususally less bass info in surrounds, but that's not the key. The key is that true, low bass is non-directional, i.e., it is difficult to locate the source. Your AVR's 80 Hz poiunt is comfortably in this zone (some say as high as 110 Hz is OK). So routing the bass info from all speakers to the sub is acceptable.Originally posted by eclypse
Which is lower fequencies for the sub? Is it 120 or the 40? Thats about the only thing that confuses me still.. Lower is the lower number and higher is the higher one? So when the sub is pumping out those that low range its runing 40-20?40 is lower than 120 hertz (Hz). A hertz is a wave measurement in cycles per second. The fewer there are the lower the frequency is...
So if i set the crossover at 80 then that means anything below that 80 like 79-20 the sub plays?Sort of... 80 is the point where the sub starts and the lows to the mains begin to roll off. The x-over point is not a wall, it's the beginning of a slope. Again the intent is seamless blending.
Oh the sub has a bypass switch so i can turn off the subs internal filter if i need to called "subwoofer direct/internal X-over".. So if i stick with the sub woofer cable i should use that switched to "Direct"since the reciever will be forced with using its internal 80hz filter... Yes
oh wait it might only use that filter when i enable THX mode on the reciever... hmmm.. Is there anyway to verify what the recievers filter is set at besides calling Kenwood? Sorry, I don't know your AVR. Someone elde may, but calling the manf is never a bad idea.
I'd like to try wiring the speakers straight to the sub using speaker wire and bypassing the recievers filters but if i do i'd have to turn off the sub woofer on the reciever... The prob i see with that is i dont see how any low bass from the center and rear channels being played from the sub only the fronts. In order to fix that wouldn't i need another sub for the rear channel and hook them up straight to the rears like the fronts?More later,
Tour...
Vox Copuli
On your last post... It's wise to invest in a Radio Shack analog SPL meter (~$35) and an AV calibration disc (couple different ones in the $20 to $30 neighborhood). The combination will help you blend the speakers.More later,
Tour...
Vox Copuli
Ok makes sense.. but let me try re-phrasing it again..
If i wire the front main speakers to the sub i'd have to obviously turn off the SW off on the reciever.. That way i'd use the X-over on the sub.. I'd have to set all the speakers to large so i'd get full range of frequencies to the speakers so the sub can do its thing with the low ones.. Now with the rear and center channels that is not hooked to the sub will i guess sound less real since they cant play the low fequencies right. right? So for example in a movie when theres a helicopter that flies over head from front to rear i'll only hear the sub work for the front but the rear sound when it goes past my head wont sound right.. So what i'm saying wouldnt i need a rear sub as well hooked up to the rear speakers?
Oh thanks for the reply! And thanks for going threw the trouble of attempting it twice since it didnt go threw the first time..
I was thinking i was going to be left hanging..Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Oh hehe just to prove how wierd it sounds when i use the sub pre out to the sub and set all the speakers to NML/THX, (the only way i can set them so the bass goes into the sub) My wife even notices that it sounds bad that way.. But when i just run the speakers without the sub and shut the sub off on the reciever it sounds fuller again.. It might just be the possition of the sub in the corner next to the fronts.. Though i thought that would be the best spot.
yeah i'll be picking up that Avia AV setup disk soon enough and the SPL meter from Radio shack forsure.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
No your question about the rears if you wire the Polk way...
With sub set to "No", the LFE should be routed to your mains, and will be intercepted by your sub. THe LFE gathers effects from all channels so it will support that helo flying at you from behind...
Sub in the corner is a good place to start, but it won't always end up being the best place to stay.More later,
Tour...
Vox Copuli
K great! Thanks for answering my question!
Now that clears it up for me... ahhh..
I cant wait to hook the system up the polk way now!
Thanks again.. Ya might of saved me a ton of cash and greif since i was going to start world war 4 with the wife for a new reciever!
but eh.. Just encase, which reciever the HK or the Onkyo has better sound for both music and HT in your opinion?Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
I'm not the one to answer this.
Denon has a good following here. Onkypo as well. HK is gathering a following...More later,
Tour...
Vox Copuli
