Volume knob on preamp
mguevarra61
I just wanted to ask someone. I have long since lost my remote on my very old NAD integrated amp and so I have to turn the volume knob manually. I noticed that there is not much sound coming out of the left speaker but when i turn the knob to the second notch, sound comes out of the left speaker. Is it because the inside of the "pot" is dirty? I am planning on buying a new preamp anyways very soon. Does anyone know how to solve this?
Post edited by mguevarra61 on
most any electronics cleaner will clear that upDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Can you recommend any cleaner? And how would I clean the volume control?
Caigs Deoxit works very well. Radioshack has a generic version that also works well.
It depends on the type of pot that's used, but generally you have to clean them from the back side. Open the top up, and you should be able to see the pot inside. There should be some kind of small hole or opening that you can spray the Deoxit in.
Caigs website has a big FAQ about how to use it properly.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
fry's sells some 99cent contact cleaner that will work just won't last as long
