How do you bridge a 2 channel amp for 1 sub??
audionewbie333
I have not bought the amp yet, I have one 12" Polk MOMO MM12 w/ yellow middle (non-recalled version). I was thinking about getting either a Rockford Fosgate 2 channel amp or a Elemental Designs Avionixx AXA 400.2, either way I need 500watts RMS. Both these amps are 2 channel amps, and I was just wondering how you bridge them for one 12" sub. Also, any other amp suggestions??? I was also thinking about U.S. Acoustics 2200 oldskool amp for cheaper than either the RF or ED amps and has 600watts RMS output bridged!
by the way, everything is at 4 ohms.
Post edited by audionewbie333 on
Post in Car Audio section of site for better results. Is later down the page on the main forum page. Good luck!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yep, wrong forum, same theory. Each manufacturer will have its own specifics, so check with the manufacturer.
Parasound: 2CH Amplifier
Right Channel +, becomes Bridge +
Left Channel +, becomes Bridge -CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
"Right Channel +, becomes Bridge +
Left Channel +, becomes Bridge -" = wrong, see below
Right on the money. I have a little Fosgate Punch60ix (back from the days when RF underated their amps), and I am running it bridged like this, and it makes my 2 Fosgate 12's hit hard.
One day, just for fun, I swapped it out with a Punch250 wired normally, and it sounded the same.
"Yes, I did bastardize a 2002 BMW 325 with subs!" -PolkThug -
LOL Thug, guess its maybe a standard configuration then...cool.
Nice to see you in the forum, bring the Bimmer by some time
I want to see them Dual 12 foot RF subs bubba! Pics please?
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hmmm... I'm starting to think I'm using the Negative terminal from the left side. Now I'm gonna have to look, if I can find those pesky hex wrenches....
I'll get some pics of the 12 *inchers* soon! -
My final answer. Okay, I took apart all my sh#t so I could get this right... To bridge a Rockford Fosgate amp, Run two wires to the right side negative (-), and use them for the speaker negatives. Run two wires to the left side positive (+), and use them for the speaker positives. Got it! Good!
or if you like:
Amp Right (-) = speaker negatives
Amp Left (+) = speaker positives
Now, I must put this stuff back together :mad:
