How do you bridge a 2 channel amp for 1 sub??
I have not bought the amp yet, I have one 12" Polk MOMO MM12 w/ yellow middle (non-recalled version). I was thinking about getting either a Rockford Fosgate 2 channel amp or a Elemental Designs Avionixx AXA 400.2, either way I need 500watts RMS. Both these amps are 2 channel amps, and I was just wondering how you bridge them for one 12" sub. Also, any other amp suggestions??? I was also thinking about U.S. Acoustics 2200 oldskool amp for cheaper than either the RF or ED amps and has 600watts RMS output bridged!
by the way, everything is at 4 ohms.
Post edited by audionewbie333 on
    VR3 Posts: 29,700
    edited September 2003
    Post in Car Audio section of site for better results. Is later down the page on the main forum page. Good luck!
  • dorokusai
    dorokusai Posts: 25,640
    Yep, wrong forum, same theory. Each manufacturer will have its own specifics, so check with the manufacturer.
    Parasound: 2CH Amplifier
    Right Channel +, becomes Bridge +
    Left Channel +, becomes Bridge -
  • PolkThug
    PolkThug Posts: 7,532
    "Right Channel +, becomes Bridge +
    Left Channel +, becomes Bridge -" = wrong, see below
    Right on the money. I have a little Fosgate Punch60ix (back from the days when RF underated their amps), and I am running it bridged like this, and it makes my 2 Fosgate 12's hit hard.
    One day, just for fun, I swapped it out with a Punch250 wired normally, and it sounded the same.
    "Yes, I did bastardize a 2002 BMW 325 with subs!" -PolkThug
  • dorokusai
    LOL Thug, guess its maybe a standard configuration then...cool.
    Nice to see you in the forum, bring the Bimmer by some time :D
    VR3 Posts: 29,700
    I want to see them Dual 12 foot RF subs bubba! Pics please? :p
  • PolkThug
    Hmmm... I'm starting to think I'm using the Negative terminal from the left side. Now I'm gonna have to look, if I can find those pesky hex wrenches....
    I'll get some pics of the 12 *inchers* soon!
  • PolkThug
    My final answer. Okay, I took apart all my sh#t so I could get this right... To bridge a Rockford Fosgate amp, Run two wires to the right side negative (-), and use them for the speaker negatives. Run two wires to the left side positive (+), and use them for the speaker positives. Got it! Good!
    or if you like:
    Amp Right (-) = speaker negatives
    Amp Left (+) = speaker positives
    Now, I must put this stuff back together :mad:
