Volume knob on preamp
mguevarra61
mguevarra61 Posts: 55
edited December 2009 in 2 Channel Audio
I just wanted to ask someone. I have long since lost my remote on my very old NAD integrated amp and so I have to turn the volume knob manually. I noticed that there is not much sound coming out of the left speaker but when i turn the knob to the second notch, sound comes out of the left speaker. Is it because the inside of the "pot" is dirty? I am planning on buying a new preamp anyways very soon. Does anyone know how to solve this?
Post edited by mguevarra61 on
  • hoosier21
    hoosier21 Posts: 4,416
    edited November 2009
    most any electronics cleaner will clear that up
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • mguevarra61
    Can you recommend any cleaner? And how would I clean the volume control?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Caigs Deoxit works very well. Radioshack has a generic version that also works well.
    It depends on the type of pot that's used, but generally you have to clean them from the back side. Open the top up, and you should be able to see the pot inside. There should be some kind of small hole or opening that you can spray the Deoxit in.
    Caigs website has a big FAQ about how to use it properly.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • analogsonar
    analogsonar Posts: 2
    fry's sells some 99cent contact cleaner that will work just won't last as long
