Video Capture Card
Disc Jockey
I want to archive some vhs and mini dv tapes to dvd. The mini dv tapes are no problem as my pc has firewire connections but I have no composite or s video connections for the vhs tapes.
I was wondering if anyone had any experience or recommendations on a video capture card. I am running Vista 64. Thanks!
DJ
DJ
"The secret of happiness is freedom. The secret of freedom is courage." Thucydides
Post edited by Disc Jockey on
ATI All in Wonder was a favorite of mine for a long time. Worth a look.Shoot the jumper.....................BALLIN.............!!!!!
Just get a dvd player that records. Might be easier, and you'll actually use it for more than just transferring media."They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
I don't really want another component and I will probably want to do a little editing so a dvd recorder is out of the picture.
The ATI solution looks pretty nice. The all in wonder doesn't offer much over my current vid card so I think I will just get the TV Wonder version instead. Plus I can get the VisionTek version off Amazon for $44 right now, so the price is right.
Any ideas for a 3rd party software solution for vid capture/conversion? The Catalyst software included with the card doesn't seem to garner much praise."The secret of happiness is freedom. The secret of freedom is courage." Thucydides -
Yeah, the ATI All-In-Wonder cards were my pick for years.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
This is what I use been using for a year havent had any problems. Transfered all my vhs about 50 with decent quility considering.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100112&cm_re=kworld-_-15-100-112-_-ProductTV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
I used a Dazzle Instant DVD Recorder from Pinnacle but I ran it on XP 32-bit. It was simple & cheap ($40 @ BB). I wasn't crazy about the DVD burning engine so I just captured to disk but other than that, it worked fine.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
