Best Wall plate hookups
flldtt
flldtt Posts: 24
What are the best wall plate hookups for my LSi's? Banana plugs or spades? Anyone have a good wall plate website? Thanks in advance for any help.
Post edited by flldtt on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited November 2009
    Wall plate's for speakers usually consist of 5-way binding posts, and those accept both spade/banana plugs. You can also use bare wire if you really wanted, just thought I'd add that for ya.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • DMara
    DMara Posts: 1,434
    You can see my setup here: http://www.polkaudio.com/forums/showpost.php?p=1203280&postcount=17
    I used banana plugs for cable mobility, but these wall plates also accepted spades or bare wires. I bought all wall plates from monoprice.com (http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10425).
    Here are a few more pics:
    • Behind TV: using the Monoprice "Recessed Low Voltage Cable Wall Plate WITH Recessed Power", running additional romex from the bottom power outlet so that I can connect the TV's power cable right from behind.
      http://farm3.static.flickr.com/2788/4148123734_810aaf5459_o.jpg
    • Speaker wall plates: notice the front left speaker wall plate: I bought a 3-speaker plate because originally I was thinking about combining the plate for all 3 front speakers. Finally I unscrewed one of the banana-plug port and screwed in the little RCA port for subwoofer that I took out from another 5.1 wall plate. The below picture showed the remaining holes, but later I used some white tape to mask them. It looked prety nice and clean.
      http://farm3.static.flickr.com/2545/4148114130_d2bbc7b0be_o.jpg
    • HDMI - coaxial - 5.1 speaker wall plates on the other side of the wall (the coaxial plates was drilled an additional hole to run cat5e and infrared cable :D):
      http://farm3.static.flickr.com/2610/4148114446_9130b57e66_o.jpg
    Monoprice got great products at great pricing. I really love that site :)
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • flldtt
    flldtt Posts: 24
    thanks Dmara. Checking it out right now.
