peachtree nova or Neuhaus t2
datnoid
Does anyone here have experience with either of these 2 channel tube amplifiers? I recently purchased a pair of Polk tsi500's that I'd like to use with my Macbook w'Apple lossless? I'm in the market for smooth warm sound.
Post edited by datnoid on
The Nova is not really a tube amp, it only has a tube in the preamp section."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks, yes i know that it is a hybrid. It has advantages of both worlds. Or so it seems.
I got to spend a good long day with the Peachtree recently, hearing it by itself and in combo with other amps and preamps. It is kind of slick in that capability of being just a DAC, or a DAC/preamp or being everything!
I'd say the DAC is it's stongest point. It'd probably do just fine in a heads up comparison with a Benchmark I'd think. And that's pretty good company! Some pretty good attempt DIY tube preamps did best its pre. And several good amps like a Pass were better, like they should be. But all in all, it was a pretty neat piece and for it's price point is certainly a nice rig.
The whole idea of it is that with your laptop and a pair of speakers, you have a system! Now you can, if you want, piece in other parts of the puzzle and try about any combo you want. Or, you can just leave it simple and enjoy!!
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
