505 Subwoofer settings
rrsjls@msn.com
I have dual 505 Subwoofers, and have the following settings:
Power: Auto
Phase: 0
Volume: 50%
Low Pass: 120
On the AVR (Yamaha RX-V863):
Left, Center, Right Speakers (VM20): Large
Crossover: 80 hz
Anyone here with more knowledge than I have any thoughts as to whether these are good settings or if not, any suggestions for changes.
Power: Auto
Phase: 0
Volume: 50%
Low Pass: 120
Crossover: 80 hz
Post edited by rrsjls@msn.com on
I have same exact set up with Onkyo TX-SR707. The only setting that I use different is I use 80 for the low pass. I read that somewhere here on the forum. Also on my receiver there is a Double Bass setting that helps out quite a bit. You may or may not have that on the Yamaha. Let me know if you find a better setting you like.My Setup:
Front- Polk Monitor 70
Center- Polk CS2
Rear - Polk Monitor 70
Subs - 2 Polk PSW505
Receiver - Onkyo TX-SR707
Amp - Emotiva XPA-5
Zone 2 Speakers - Polk M40
CD Player - Emotiva ERC-1
Interconnects - Emo X-Series
& Emo Ultra speaker cables
additional components:
Television - Samsung LN52B750
Gaming Console - Microsoft XBox 360
Media Center - Gaming Computer with Blue Ray Drive -
I changed the Low Pass to 80 and I do think I like that better than the 120 I had it set at before. Thanks for the suggestion.
rrsjls@msn.com wrote: »I have dual 505 Subwoofers, and have the following settings:
Power: Auto
Phase: 0
Volume: 50%
Low Pass: 120
Crossover: 80 hz
Try taking your sub back up to 120, and setting the Yamaha to "Small" for all speakers, and try both the 80 Hz and a 90 Hz setting in the AVR. Welcome to CP.
