Which PJ screen???
PSOVLSK
PSOVLSK Posts: 5,380
edited November 2009 in Electronics
I think I've narrowed it to these two which seem to be basically the same except for the size and the frame.
http://www.htdepot.com/Focupix_Widescreen_Silver_Frame_Screen_112_Grey_p/ffs169gy-106.htm
http://www.htdepot.com/Focupix_Widescreen_Fixed_Frame_Screen_115_p/ff169lt-110gy.htm
I have a dedicated room that is pitch dark with all the lights out. I think a grey screen is what I need, but someone please correct me if I'm wrong or feel free to offer alternative choices in the same price range, ie <$400.
I currently have a homemade screen made from blackout cloth. It has served me well, but it's time to see what improvement I get out of a "real" screen. Since the homemade version was only $35, the improvement needs to be pretty substantial...especially since my wife thinks it's ridiculous to make this purchase.
I guess I could add that the alternative is keeping my current screen and picking up a new turntable. I have my eye on a Rega P1 unless I can find a better deal used.
Post edited by PSOVLSK on
  • mshan242700
    mshan242700 Posts: 823
    For several hundred dollars above your budget, you might want to look at Carada: http://carada.com/
    At rock bottom price, perhaps Monoprice.com?: http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10829
  • Sherardp
    Sherardp Posts: 8,038
    With your pj you don't need a grey screen. Blacks are pretty good with these newer PJs so a Matte white screen will do you just fine. Focupix screens are ok but I think you can get better quality for your money by going with an Elite screen. Here is 106" from Amazon in your price range. I personally own a Carada screen and will definitely tell you it is also very good but you will pay a tad bit more. Grimster74 has the Elite screen and again it is very good so whatever fits the budget should work. Definitely go Elite over Focupix though. I normally recommend the Focupix when on a tight budget. See Grim's and I showcase for pics of both.
    http://www.amazon.com/Elite-Screens-EzFrame-Projection-Screen/dp/B0014UTNNK/ref=sr_1_7?ie=UTF8&s=miscellaneous&qid=1259101357&sr=8-7
  • kuntasensei
    kuntasensei Posts: 3,263
    Yeah, definitely get the Elite if you can. I'm using a 100" manual pulldown from them, and it was a significant improvement over my 92" Da-Lite (which oddly created a moire pattern when I switched to a 1080p projector, so stay away from Da-Lite).
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • PSOVLSK
    I ordered the Elite from Amazon for less than the Focupix...which seems very good since you all agree that it's a better screen. It should be here tomorrow.
    Sherardp: If you're ever in the Dallas area you should hit me up for a drink or two. The video portion of my HT is pretty much based on your recommendations;)
    Thanks for the help.
  • Sherardp
    PSOVLSK wrote: »
    Sounds good, and I'm sure you will be happy. Pics when you can would be awesome.
