PSW111 or PSW10
Luiquroj
Luiquroj Posts: 26
Only to ask what subwoofer u prefer?
My system for the moment is 2 monitor 30, 1 cs10 central and later i will buy 2 monitor 50 for my room (2.5m x 4m)
TV: Sony KDL-32LL150
Front: Monitor 50 | Monitor CS1
Center: Monitor 50
Rear: Monitor 30
Control: Sony RM-VL600
Receiver: Sony STR-DG510 5.1
HTPC
Case Armor+ Mx
Logitech Mx Air Mouse
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB
Post edited by Luiquroj on
  • SivaNevets
    SivaNevets Posts: 303
    edited November 2009
    psw111 for music psw10 for movies. i was debating between these 2 then the sale on psw111 end. i got the psw10 (on sale and chaper),i feel it hard to blend with my RTI6. It does slightly better job than PSW111 in movies.
    now im thinking either to get another psw10 or step up to Micropro 1000 or DSWPro500
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
    That's a tiny room but I'd think the 111 would be PERFECT for it...a lot tighter more musical bass and it can go as low and lower than the PSW10...and has more a more powerful amp....it's also pricier!
    cnh
  • Luiquroj
    Luiquroj Posts: 26
    I want to use it for movies so... Then is better the psw10?
    Center: Monitor 50
    Rear: Monitor 30
    HTPC
    Case Armor+ Mx
    Phenom 9950
    Asus M3AT8-EM
    OCZ ModXStream 600W
    OCZ 6400 2GB
    WD 500GB
    PSW111 has more power and more controlled bass I would think that it would be better in general than the cheaper PSW10.....which has a tendency to chuff and bottom out...a lot of port noise from the PSW10 if you overdrive it for movies...
    If I'm not mistaken the PSW111 has a 150 watt amp...the 10 is only 50 watts. And in terms of Dynamic or peak power the 111 has 3 x the power 300 watts vs. 100 watts for the PSW10...though the 10 reaches 2 hz lower that is NOT a hearable difference..and the 111 should play LOUDER with less PORT NOISE!!
    THe 111 is better all-around for a small room...will put out less distortion.
    cnh
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    I have a psw10 and actually fills the room sort of well. I do however wish that it could go lower for movies such as transformers and some music as well. That being said for a budget sub you can not go wrong with it. But I will say I wish I had waited to get something bigger. So my vote has to go with the psw1o as it just seems to be a great sub that can do what I want it to do. "at least until I get money for a bigger one"
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • RuSsMaN
    RuSsMaN Posts: 17,985
    One tweak for each.
    The 111 is light, and really tightens up with some added weight on top, like a 25lb bag of lead shot.
    The 10 offers more volume, but the port can chuff at higher levels - adding a couple big fistfulls of Polyfill will remedy that in short order.
    Both are great when used within their limitations.
    Cheers,
    Rooster
  • bigaudiofanatic
    Not to hijack but what would be the next step up from a psw10? For someone that wants for bass for music and movies.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    PSW505....in the 250 dollar category---discontinued but good...otherwise the new DSW digital sub line see PRODUCTS ABOVE...the 500 or the 600.
    cnh
  • selkec
    selkec Posts: 187
    I just got the 111 today for free after getting 2 new rtia9's in cherry for 399 each at frys. I like the 111 better then the 10. My mom just got the 10 and it has too much port noise when running hard. The 111 has none. If you can deal with port noise then the 10 is the way to go. But all in all not alot of difference. Neither are monsters or very powerfull.
