Identify these speakers...
dudeinaroom
dudeinaroom Posts: 3,609
edited November 2009 in Speakers
if you can. Guy wants 30 smacker for them.
Post edited by dudeinaroom on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    It's a mid 80's Pioneer phenolic cone tweeter, and common CTS / Phillips midrange, can't identify the woofer, may not be original. Could be an RTR, regardless nothing to write home to mom about.
    Cheers,
    Russ
    Man I don't know what that is...it looks like its had its drivers 'switched' out...those bass drivers could be JBLs...the rest who knows......it's hard to tell from the pic if that tweeter is a DOME or a CONE? Can you tell?
    Lots of speaker designers made cabinets that looked like that years ago....Advent, KLH, etc.
    Got me...anyone else have any ideas?
    cnh
  • RuSsMaN
    Yeah, the woofer does look like a JBL, but that's no Lansing speaker.
  • dudeinaroom
    The cabinets kind of reminded me of Mirage speakers. Yes those do look like the penolic ring tweeters pio. used to use. I was thinking the woofer were JVC, but are missing the gray trim ring, and with out the ring they were just unpainted metal.
  • RuSsMaN
    Yeah, f it. If they work, offer him a 20 spot and have some fun with them in the garage. The logo on the bottom looks like an RTR logo.
    Cheers,
    Rooster
  • hearingimpared
    hearingimpared Posts: 21,136
    RuSsMaN wrote: »
    Cheers,
    Rooster
    You are spot on Russ. I've owned RTRs in the early 80"s.
    Tony M Posts: 11,731
    RTR's with replaced woofers?They probably sound good ,no?
    I have Hartley speakers that look just like them but shorter. Very expensive speakers for Jazz music.
    The tag seems to short to say Hartley though.:(
  • dudeinaroom
    are they even worth it. No garage to speak of here at the trailer in the woods. If they had grills I'd let my in-laws know so they could replace the awful blose speakers with the star drivers, that they replaced their Acusta flex speakers with.
