Sweet looking SDA2Bs (studio) on ebay (Iowa)
gdb
These look virginal with boxes & IC cable !!
http://cgi.ebay.com/POLK-AUDIO-SDA-2-STEREO-DIMENSIONAL-ARRAY-SPEAKERS-SDA2_W0QQitemZ320451442045QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item4a9c64f57d
Post edited by gdb on
Those aren't studios."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Well if not....what then? The boxes are clearly marked "Studio" ! I've always thought that that config. (w/out top and bottom slabs) were considered studio models be they black or wood/vinyl. Please educate if you will, and thanks in advance !:)
Hmmm...they are marked as 2B's, have the studio version cabinets, but have the dark walnut vinyl instead of the usual black ash vinyl. I'm going to have to say they are the studio version.Political Correctness'.........defined
President of Club Polk -
Aren't they 2As?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
No, the 2A cabinet base is different and uses the blade/blade IC, these are pin/blade.Political Correctness'.........defined
I thought "studio" cabs were black, I stand corrected.
FWIW, we know their labeling wasn't always 100% correct."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I made the same mistake in the past Mike. Looking closely at these they are an early version of the 2B's as the label shows a blade/blade connection, but they are actually pin/blade. I'm inclined to believe these are leftover 2A cabinets with the riser removed making them into the 2B studio version. I'm 99% sure that all the later 2B studio versions were the black ash vinyl that we normally see.Political Correctness'.........defined
Here is what looks like the one of these same photos in a Charlotte N.C. ad..
but after looking again right now I guess it's another BOXED pair.
http://charlotte.craigslist.org/ele/1437174749.htmlMost people just listen to music and watch movies. I EXPERIENCE them.
There are a couple other people on the forum that have very early 2B's that used 2A cabinets.
Those cabinets look exactly like my 2A's. The pin/blade IC means they're definitely 2B's though. My 2A's are blade/blade.
At that price...it'd only really be a good deal with local pickup IMO.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Monmouth IA is right off Hwy 64 on one of the routes I use to get back and forth from IL to the farm in IA. I think the starting price is a little high, but if someone is interested I could get these back to the Chicago area for them.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
They may be military base specials... they are identical to my first pair of SDA's that I purchased from the audio exchange in Iwakuni JapanThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
comfortablycurt wrote: »There are a couple other people on the forum that have very early 2B's that used 2A cabinets.
I've got some 2Bs with that type of cabinet plus the riser/plinth/pedestal, in light oak vinyl ! Screwy, to say the LEAST !!!:eek: -
This reminds me of my SDA 1/1A conundrum...SDA1s with SL1000 tweeters marked as 1-As... oh well, little mix ups make the older product lines more interesting any way.
